0 Members and 3 Guests are viewing this topic. Read 218597 times.
I'll bite. Why do you need a nearfield measurement?
I'm a data whore and always take measurements of each driver to make sure there isn't anything out of the ordinary before taking room measurements. This is a great way to make sure everything is wired properly and there isn't any damage. Good QC check.
That's beyond nearfield... At that distance the horn is nothing more than a little gain in the lower region.
Awesome!!
Hope you're eating your spinach is preparation
No doubt. I think they're about 140 lbs each. That's the only downside to them but you can't have it both ways, that's for sure!
Just imagine if the motor were ferrite instead of neodymium! Could be worse!Best,Anand.
Used M2's -$6799
Can you just run these M2s with a regular 2 channel or 4 channel amp or do you have to use the dsp amps with the software for speaker adjustment?
Yikes Makes big M2s look puny. Bet you can't wait to watch Jurassic Park.
