0 Members and 10 Guests are viewing this topic. Read 193277 times.
Great question! I'm using this to get everything in place to see what lengths I'll ultimately need once everything is in it's final position after measurements. Then I'll get the awesome DH Labs Q-10 Signature for my speakers. They're already making some Air Matrix using the Crown Phoenix connectors.
Help me understand a bit better as to where you are coming from. Yes, the M2 does have a slightly wider horizontal dispersion than some other waveguides at 120 degrees. Are you implying that for this reason a purpose built listening room should be used?I think the argument should go back to something more polar plot related than anything else. Without this sort of data your ability to assume what it may sound like in space is a complete crapshoot. Why? Well, it has been proven many times over that we not only hear the direct sound but reflected sounds. In the home environment we will likely be dealing with many reflections. The more alike the indirect or reflections mimic that of the direct sound the better the sound field. The only positive I see to a narrower dispersion pattern is that of reducing early reflections. This part has been proven to be more of listener preference for added spaciousness than anything else. I would rather have a loudspeaker with known polar data than a speaker with no data in a built room. I will have to do a few, if any, treatments to a room with good speakers. I will never be able to fix a loudspeaker based problem with a room based fix.
He's retired from speaker building and is making stained glass art from what I understand.
.......I will never be able to fix a loudspeaker based problem with a room based fix.
Your using copper clad aluminum lamp cord on a 20k speaker.
2) Find one of the fine cable vendors here on audiocircle to give you a 30 day audition of some bad ass speaker cables so you can at least do a comparison with that lamp cord crap from amazon.
1) Place each speaker on a pair of Isoacoustic Stands the way Frank Fillipeti places his.
Same drivers, yes. Different crossover and waveguide.
Oh yes, that's right.BUT, why bother with a good DAC if you're just going to convert it to digital and back again to analog?-Jim
Sitting at a console is very different in terms of height. When I was at JBL I asked them about the Iso stands..
If you read his post after showing off the lovely Amazon Basics speaker cable .....
You don't think that the quality of data going in has to do with what comes out? I'm really asking your opinion.
Great question! I'm using this to get everything in place to see what lengths I'll ultimately need once everything is in it's final position after measurements. Then I'll get the awesome DH Labs Q-10 Signature for my speakers...
That's unfortunate, though admittedly I have no idea what makes a speaker cable "awesome." That's just not a word I'd use for bog standard commodity parts.The one thing I would do with an M2 or any biamped speaker is use wire that looks different for HF and LF. Generally, I use "in wall" type cable containing red/black/green/white wires.
As proof I am sure you can find plenty of examples of M2s in dedicated rooms. Studios wouldn't spend the money on room acoustics if they didn't think it was an advantage.
Finally, the Harman preference testing for dispersion is confounded by not taking into account listener acclimation.
We get used to hearing direct radiators and hear 1st reflections as "spaciousness" but without acclimation to a narrower dispersion pattern and allowing the brain to get used to the different presentation the preference testing is confounded and near useless.
My "awesome" is that it's constructed well and just a no nonsense type of cable or company as they started in the pro world.
The Amazon stuff is of poor physical construction then?Btw, I couldn't find anything confirming EG was out of speaker biz. Joking perhaps?
AJ,He's out: http://www.gedlee.com/Loudspeakers/Loudspeakers.aspxBest,Anand.
