Supravox drivers
0 Members and 1 Guest are viewing this topic. Read 2467 times.
inrank
Supravox drivers
« on: 29 Mar 2017, 03:54 pm »
Hi Guys,
I am looking to build a pair of speakers based around the Supravox 165-2000 wide range driver. I plan to use it in a large ~70 Litre Aperiodic enclosure, build to go up against the rear walls.
I have decided on the 165-2000 as I have heard the 215-RTF64 before in OB and really liked them, but I don't really have space for a big OB setup, hence looking at an aperiodic enclosure to tame the high Q of the 165-2000.
I plan to use my DIY Decware Zen, so came to the 165-2000 with its mix of sensitivity, midrange performance and bass. I have had the Veravox 5S previously and this is probably the closest available driver, although a little larger.
I notice that the 'EXC' Field Coil version is very similar price but unsure about a PSU for it, in a simple domestic system.
Has anyone had any experience with either the 165-2000 or 165-2000 EXC?
Re: Supravox drivers
« Reply #1 on: 29 Mar 2017, 04:40 pm »
This brand is rarely owned in US, you should check w/Supravox guys your plans, the 165 Coil PSU is a low voltage, just 5 to 10V.
inrank
« Reply #2 on: 30 Mar 2017, 06:55 pm »
Thanks, the Field Coil version actually looks better in a sealed box with the lower qts (@10v).
I read somewhere that Field Coils need good ventilation?
« Reply #3 on: 30 Mar 2017, 10:07 pm »
Correct, it build heat more than magnets.
If the coil operates at low basis it should warm up little, but if the coil are small or works at high basis regimen (+50%) it should heat more.
« Last Edit: 31 Mar 2017, 04:46 am by FullRangeMan »
