FS: Squeezebox v3 with Boulder Digital Mod
0 Members and 1 Guest are viewing this topic. Read 1185 times.
04dgmsilv
« on: 18 Mar 2017, 05:33 pm »
Have a Logitech SB3 that has been sitting in the closet for a few years now and needs a new home.  This is the wireless black version and has the Boulder digital mod done to it.
Here is the description of the Boulder Mod:
The Digital Only modification is the first level of internal upgrades in the Bolder Cable Company lineup. A Squeezebox with this modification package is intended for use with an external DAC, or in a home theater system where a digital to analog converter is housed in another component. Every Bolder modification package starts with an upgrade to the internal power supply stage of the Squeezebox. All of the power supply capacitors are replaced with a combination of Panasonic FC or Blackgate NC capacitors. Since the internal power supply distributes the current to all the circuit stages in the SB3, these upgrades improve both the digital and analog stages of the Squeezebox. The second half of the digital modification addresses the architecture of the digital output circuit. In the stock SB3, the output of the digital buffer passes through a circuit containing various parts, which includes several inductors and complicated board traces. Wayne has bypassed this portion of the Squeezebox, and installed a proprietary 75-ohm wire, and a 75-ohm WBT NextGen RCA output connector. Now the SB3 has a true 75-ohm output level, which the optimal configuration to interface with a separate digital to analog converter.
Pictures are here:
https://goo.gl/photos/XhccxfCRsPGs768P9
Condition:
The SB3 itself is in very good condition.  Comes with the original box, manual and power brick.  The same cannot be said of the remote.  The original SB3 remote is lost.  What I have included is an old SB Touch remote that the soft touch rubber coating has disintegrated and gelled into a sticky mess that glued the battery cover onto itself that I had to break it off to get batteries into.... It's a mess, but it works and you only need to use it for initial setup, then just use an app, ipeng or Roon if you are using that.
Price:
$125 Shipped/Paypal included in CONUS.
« Last Edit: 25 Mar 2017, 02:18 pm by 04dgmsilv »
04dgmsilv
Re: FS: Squeezebox v3 with Boulder Digital Mod
« Reply #1 on: 25 Mar 2017, 02:18 pm »
Price Reduced.
04dgmsilv
« Reply #2 on: 7 May 2017, 11:33 pm »
SOLD!!
