Poisons will also kill birds of prey when they scoop up dying and dead rodents outside, so not such a great thing
Bear and his kill.And one for scale!
Bear is worth his weight in gold! How big is he?
If they are inside the house, that means that there is a hole somewhere where they come in. In NYC, in an apartment building I used to live, we used to get mice in Winter. The rodents used to climb up through holes in the walls or even worse, the steam pipe plumbing where they used to squeeze through the floor and the heating pipe. It was advisable to fill such spaces with brillo/steel pads and then seal it with caulk. They cannot chew through brillo and if they do, they die. Traps are good for a trapped population that will not expand but if the holes to the house are not sealed, it will be a problem dealing with this.
