MPD Buffering on BDP-1
0 Members and 1 Guest are viewing this topic. Read 1697 times.
Krutsch
« on: 16 Mar 2017, 09:27 pm »
I've been encountering some stuttering issues at the very beginning of audio tracks that are large (i.e. 192/24).
I host my library on a pair of Corsair GTX flash/thumb drives that test quite well, speed-wise, from the command shell on the BDP-1:
time dd if=/dev/zero of=/media/MUSIC-256/test_file bs=8192 count=331541
331541+0 records in
331541+0 records out
2715983872 bytes (2.7 GB) copied, 195.432 s, 13.9 MB/s
After some trial and error, I discovered that I could completely eliminate any stuttering by slightly bumping up MPD's default setting for playback buffering.
I did this as follows:
1. Mount BDP-1’s USER share via SMB
2. Edit: MPDCONF.SET
3. Add: buffer_before_play;20%
4. Reboot BDP-1
This will add the line below to /etc/mpd.conf to increase playback buffering which seems to remove stuttering at the beginning of 192/24 tracks (this was universal across all of my larger, high-res tracks). Playing back an album would be smooth, but tapping on a specific track would result in a stutter at the very start of the track.
buffer_before_play   "20%"
Would be super-cool if this setting was available in the Manic Moose MPD configuration page, along with the ability to toggle REPLAY_GAIN playback.
CanadianMaestro
Re: MPD Buffering on BDP-1
« Reply #1 on: 17 Mar 2017, 12:30 am »
How long's your playlist? I generally find that if my list is very long (say > 300), I get stalls and have to reboot, occasionally. Not often.
Did this 192/24 issue just crop up? Do you see it happen with 96/88?
unincognito
    • bryston.com
« Reply #2 on: 17 Mar 2017, 12:51 am »
Granted I havn't tested that feature since loony loon days but I recall MPD's seek feature would become unstable.  This is why the mpdconf.set and mpd.append files exist.
Also I don't feel /dev/zero can give an accurate read of the bandwidth available, granted your options on a BDP-1 are limited.  I would dd as much of /lib/live/medium/mount/live/filesystem.squashfs (I might have medium and mount backwards) into a file in /dev/shm and repeat using what you did but with the portion of filesystem.squashfs that you copied.
Cheers
Chris
Krutsch
« Reply #3 on: 17 Mar 2017, 03:28 pm »
In my tests the playback queue only contained a single album. Again, it didn't matter which album - only the sample rate / bit-depth.
This issue has been relatively recent, but not sure which version started this behavior.
This was ONLY happening with 192/24 tracks - 88.2, 96 and 44.1/48 tracks were just fine.
Since making this change, I've not heard a single stutter (played a lot of music last night) and the change in start-up delay was very minor, so I'm leaving this change in place.
Krutsch
« Reply #4 on: 17 Mar 2017, 03:32 pm »
Cheers
Chris
Fair enough. Here's the same thumb drive tested with Manic Moose "Bench" feature:
Benchmark Results
14.1MB/s
...number is actually a little higher than what dd reports.
As for seeking, I did quite a bit of that last night, re-listening to guitar riffs on a 192/24 album. No issues on my system with seek and playback.
CanadianMaestro
« Reply #5 on: 17 Mar 2017, 10:14 pm »
Glad it's all good now.  :thumb:
Krutsch
« Reply #6 on: 21 Apr 2017, 01:56 pm »
UPDATE: with the latest BETA release, S2.33 2017-04-07, I am now experiencing stuttering at the end of a track, presumably from when MPD is trying to load the next track in advance of playback.
So, I tried some different values and changed from 20% to 15%. Now I can reliably play 192/24 gapless tracks w/o stuttering at the beginning or end.
This drive is pretty fast even in USB 2.0 Hi-Speed mode, but it's not as fast as my Samsung EVO 1TB. I may need to consider going back to that drive if I still have problems.
Probably time to consider upgrading the BDP-1 to something with USB 3.0 and/or GigE ports and enough RAM to not be running at 98.5% utilization all of the time...
