0 Members and 1 Guest are viewing this topic. Read 6478 times.
Speaker positioning and especially toe-in play a huge role in the speakers "disappearing" act. My system(s) sound best when there is lots of "air" in the recordings. To achieve that, I have found that they must be symmetrical to the room and each other. I have them measured to 1/32" to a sound that I want. This (IMO) has way more merit then any effect with the associated electronics connected to the speakers.'ner
Once you have your room set up optimally, you might as well take the recordings as they come.
Once again, I am truly amazed how touchy it is when adjusting my test speakers in my 13' x 27' room. 1/32" movement, whether forward or backward, rotating, or tilting of the speakers. Besides that, I have three adjustments on the xover, on the back that I can adjust. And just the slightest bit adjustment of any of them and the sound stage, tonal balance, bass damping, naturalness etc changes. With just the slightest change, the sound can be overly full, or too bright/edgy etc, and sound questionable. Again, I am adjusting the tonal balance in the -105db range (reference fundamental) and the naturalness just changes. The advice I have is to take one's time when setting up their speakers, and if possible, purchase speakers which have adjusting controls as well.CheersSteve
I just have to chime in on this thread. 1/32 inch of adjustment to achieve "audio bliss"?? To achieve this on a repeatable basis, you must be using something like this in your setup:My approach; try a little toe-in, move them in or out a little and settle on a position that sounds good from where I sit and enjoy the music. Move them based on genre? Thats a crazy amount of work IMHO. I am an engineer, and firmly believe in the KISS principle.Regards,Steve
Sound travels 13,200 inches per second in air near sea level, so 13,200 Hz sound waves are 1 inch long and 422,400 Hz is 1/32 of an inch long.
I am not sure what you mean J and Sled?The determination is how much of an octave is accompanied by the amplitude variation. Rane has determined that it takes about 1/3 of an octave width before we perceive it. So if there is a sharp dip 1/4 of an octave wide, we most likely will not perceive any change in sonics.If there is only a slight change in amplitude over several octaves, this will be perceptible.Simply move one's head and check for any deviation in perception.CheersSteve
Really nothing more to add to this discussion other than confirmation as to why many feel these types of posts suck the life and fun out of audio.
Almost none of us have symmetrical listening rooms. If you add in the acoustical properties of doors, windows and the different properties of exterior & interior walls, none of us have symmetrical rooms.
I was just looking at photos of Siegfried Linkwitz's listening room. No way to make measurements in a room like his. When your room sounds as good as his, let us know.
Does not need to be as the adjustments are just as critical on excellent systems.CheersSteve
non-sequitur?
