Would love to hear how the BOT works with the PI? Anyone?
0 Members and 1 Guest are viewing this topic. Read 2172 times.
wplash666
Hi, just wanna archive my cd collection as BIT perfect as possible, will these work?
wplash666
Re: Would love to hear how the BOT works with the PI? Anyone?
« Reply #1 on: 18 Mar 2017, 08:05 pm »
Really, Nobody?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 18 Mar 2017, 09:16 pm »
Hi wplash
I use the BIT with my BDP-3 and it works great - I will try it with the Pi this weekend and let you know.  The Pi is not as powerful as the BDP-2 so it may be on the slow side when ripping.
james
schmidtmike76
« Reply #3 on: 18 Mar 2017, 10:55 pm »
Thanks James for looking into this.  I myself would like the BOT to try with my Pi with some CD's if it works.
wplash666
« Reply #4 on: 19 Mar 2017, 02:56 pm »
Cool ,Thanks!
« Reply #5 on: 19 Mar 2017, 07:23 pm »
OK I ripped about 10 CD's and no issues.
Other than I would recommend in the Ripping menue in Manic Moose set it up like this:
The 'Disable verification' saves a lot of rip time  - takes about 4 minutes per CD.
schmidtmike76
« Reply #6 on: 19 Mar 2017, 08:35 pm »
Think I know someone who will be buying a silver one.  How do cds sound through it into the BDA-3?  That's the real reason I want it.  After you ripped a cd did it automatically store it in the same folder as the artist that's already sitting on the Pi
« Reply #7 on: 19 Mar 2017, 08:57 pm »
You can only use it with the BDP not the BDA3.
James
schmidtmike76
« Reply #8 on: 19 Mar 2017, 09:02 pm »
I see I thought I could play cds through it.
« Reply #9 on: 19 Mar 2017, 10:38 pm »
Hi
You can but it has to be connected to the BDP-2 then it is outputted to the DAC.  So when you are listening to a CD you are hearing it from memory on the BDP.
james
Krutsch
« Reply #10 on: 20 Mar 2017, 09:39 pm »
Hi
james
Is the BOT-1 still supported by the BDP-1?
« Reply #11 on: 20 Mar 2017, 10:46 pm »
Hi Krutsch
I have not tried it but Chris may know.
james
unincognito
    • bryston.com
« Reply #12 on: 21 Mar 2017, 12:00 am »
Yes, is your BDP1 not working?
Krutsch
« Reply #13 on: 21 Mar 2017, 07:58 pm »
My BDP-1 is working great.
I was reading the questions about support for BOT-1 on the BDP-Pi and just wanted to ask if the BDP-1 was still supported with the BOT-1.
