0 Members and 1 Guest are viewing this topic. Read 19845 times.
This is what I worry about too. Trying hard to keep it at least budget friendly.
For $35 you can buy a moka. No Italian in his right mind would spend $500 plus on a expresso machine. What have you got to lose. Try one before you spend big bucks.Doc
Well, it's only fair to tell all those who pitched in on this thread what I actually ended up buying. First off, thanks to all who insisted a more upscale grinder was a must ......even before the espresso machine. Sorting through all the suggestions was truly enlightening. Unfortunately, it became pretty confusing as well. After about a week or more of additional information gathering, (and further confusion) I decided to call one of the bigger online retailers for everything coffee and speak to a consultant. I thoroughly explained my goals and rough budget of around 1K for both machine and grinder. To my shock, he came back with two suggestions that totaled a shade less than $500. I guess he was trying to say that within my budget, these two products offer the best value....regardless of the fact they only added up to half my 1K budget. The beauty of this whole consultation was he made no attempt to upsell or expand my budget. So it must have been obvious to him I was only a semi-serious coffee snob. He bluntly told me to buy a Gaggia Classic and Baratza Encore burr grinder and enjoy. Yep, so I reneged on my claim that I would not by another Gaggia. Needless to say however, the Classic is far more serious machine than the Carezza. For those who stressed the importance of a decent grinder, you were indeed correct. I now feel I have a lot more control of the final coffee product with the refined grind settings on the Encore. So in summary, I'm quite happy with this fairly economical purchase. I know neither will elevate me to full coffee snob status, but they certainly took me several rungs upscale from where I was. Thanks again to all who shared their thoughts and knowledge.
Yes, they all use moka's at home and go out for espresso. There's a reason for that. It's called taste. A higher end espresso machine is for someone who wants an authentic espresso at home. If you just want "good coffee", you use a moka.BTW, I think my Aeropress makes better coffee than any of the many moka machines I've owned.
So far .....superb. The Encore is a revelation for me. I was coming off a Braun my ex-wife picked up years ago at a yard sale. It was still sealed in the box priced at $5. Not a bad little burr grinder that I much preferred over a newer Cuisinart. That all said, the Encore is in a different league. My first experience with truly "tuning" the grind. On to the "Classic". Far, far superior to my old Gaggia Barazza. I've pulled more crema out of the Classic in the last month than the Barazza kicked out in 8 years. One caveat must be brought up however. I bought a "refurb" Classic from WholeLatteLove. It came in like-new condition and worked beautifully for 2 weeks before I had to clean the solenoid/valve assembly. The PDF on this procedure can be sourced within minutes from WholeLatteLove. Fairly easy procedure, especially if you're mechanically inclined. Metric Allen wrenches, Phillips screwdriver and needle nose pliers are the tools needed. I'm guessing this issue might not surface as quickly if the machine were bought new....but I'm only guessing here. So basically
Realized that buying coffee/espresso equipment is pretty much the same as audio - the more you research, the more expensive it gets. I even saw a review mentioned spouce approval factor of the look as an important factor for the the purchasing decision.
I've tried making espresso using the Aeropress, along with developing good crema, and found the Aeropress to be a million miles away from producing a real espresso. Thee YouTubers who present their Aeropress espresso's are delusional:) So encourage your journey to get a lever machine if you want to enjoy a good espresso.
