0 Members and 1 Guest are viewing this topic. Read 12972 times.
SRB is correct, the TJ Max web site wont show what they have in the store.. Another related store is Home Goods.. You could probably even find bamboo cutting boards at Bed Bath and Beyond, they do have an extensive website.
Amazon has more cutting boards than you can shake a bamboo stick at. I have also seen nice ones at Big Lots.
A platform stone will no ring itself, the ring effect is a resonance in the return way from the plat to the amp or turntable etc, if turntable it will reach the needle and the entire capsule as a smear signal.
Thanks for that FRM. If the granite is vibration isolated, sitting on isolation pads that also, in effect dampen it, certainly changing it's resonant frequency, how would that be a conduit to anything resting on it that is also vibration isolated from the granite or any other material with similar density?I'm curious to know if an app for my phone would be able to measure the vibration in a relative way to find a best all around material.Just trying to understand where the chain can be broken..
Hi Guys,Has anyone tried granite as speaker or equipment platforms? I have read that while they can enhance bass and impact (good), they can also thin out the mids and increase treble energy (bad). Could this be possible? I would be most grateful for feedback and perhaps a recommendation for an alternative. Thanks!
I guess I don't understand this concern about ringing at least in this context.
... my beryllium cantilever core is one of the hardest metals know to man, this helps too, as no groove info is lost in route to magnets.
Once upon a time I went to our local granite supplier to purchase a pair of granite slabs to place under a pair of speakers. After listening to what I wanted to do with the granite the supplier suggested I use soapstone instead because, in his words, it would "ping" less than granite. FWIW.
It might be worth further investigation, as soapstone is a kind of natural composite material ... you know ground soapstone by it's household name ... talc or talcum powder.
Is soapstone is the stuff used in high school chemistry labs? If so, how does it ground into a fine white powder? Just curious.
Actually the physical properties of beryllium that make it desirable for that application are its high stiffness and light weight ... beryllium only has medium hardness, ~ 5.5 on the 10 point Mohs scale.
