0 Members and 1 Guest are viewing this topic. Read 9671 times.
Wireless speakers is a silly feature, wire are used to taylor the sound to a personal taste.
Is it not better to use tone controls to tailor the sound?
Its all about personal taste.
So you use wires to fix a 10db peak at 60hz? Or overly bright recordings? What happens if the recording is too dull?Those must be some wires.
Yours of course, being not silly like the wireless folks. So you use wires to fix a 10db peak at 60hz? Or overly bright recordings? What happens if the recording is too dull?Those must be some wires.
I believe he meant using wires to "fix" speakers, not recordings.
You need an equalizer
Right, whereas a tone control can fix both.
With as fast as things like DACs or DSP type devices are changing/advancing/improving, keeping this in the discussion of actives as they apply to audiophiles who are continuously in pursuit of better sound, wouldn't having all of that stuff built in to the speakers mean that as soon as "next year's model" - or in the case of some electronics these days "next week's model" - comes out, wouldn't an audiophile basically be pressed into tossing an entire "system" to the curb rather than flipping a single component of a less integrated system?Maybe the "audiphile" answer to active might involve some sort of modular design, kind of like one trait that has made LIO so popular? Sure, an active speaker would still be a somewhat closed system to a single manufacturer/designer, but if the thing were engineered from the start to be able to easily swap out the electronics (either with repair/replacement parts or upgrades as new improved tech comes out), it might be one way to give the concept some longer legs among a customer base continuously chasing technology?
Tone controls create more problems than they solve. That's why most audiophile manufacturers omit them.
Why not just buy speakers with flat frequency response?
Speakers with a flat frequency response -- that's what studio monitors strive to achieve, but they don't necessarily sound good simply because they measure flat.
