0 Members and 1 Guest are viewing this topic. Read 8225 times.
You can also bathe in it.
This may works, seems it is in her skin, any bactericidal soap.
Trehalose has ABSOLUTELY ZERO ANYTHING AT ALL TO DO WITH BACTERIA. The idea is absolutely ludicrous that there's a relation between bactericidal anything and Trehalose. It's like saying if oil lubricates a car's engine, than a saline solution surely would too. Trehalose helps old cells not produce the smelly stuff by supporting them internally.
I suggest soap and water, what you have in your sleeve better than it?
Stopping cells from making the odor, instead of removing it briefly as you suggest.
No, this does NOT belong in the Karma Circle, we are NOT giving away anyone's mother.Take up smoking cigars, then you wife can complain about the stogies.Tell her to deal with it and live happily ever after.
With old skin, it's not a good idea to shower/bath more than twice a week to avoid breakdown.
I've read a bit about ozone units and ionizers and I need to find a solution.
Although technically, that would solve sonicxtc's dilemma
