bryston bcd 1
Jeff Braecklein
bryston bcd 1
« on: 12 Feb 2017, 05:41 pm »
How often should the unit be serviced and approximately how much does it cost. Thanks, Jeff
  • The Demo is Everything!
    • http://www.bryston.com
Re: bryston bcd 1
« Reply #1 on: 12 Feb 2017, 06:09 pm »
Hi Jeff
Unless there is an issue no service is required.  Usually DRIVES are what wears over time.
james
sweetspot
Re: bryston bcd 1
« Reply #2 on: 12 Feb 2017, 06:36 pm »
James,  If need be, are you still able to service the BCD-1, going forward?
Re: bryston bcd 1
« Reply #3 on: 12 Feb 2017, 11:23 pm »
Yes no issue - we still have lots of parts.
james
CanadianMaestro
Re: bryston bcd 1
« Reply #4 on: 13 Feb 2017, 12:07 am »
james
Can BCD-1 be fitted with the Sony CD tray as in the BCD-3 -- cost?
Drive too?
Phil A
Re: bryston bcd 1
« Reply #5 on: 13 Feb 2017, 12:32 am »
Probably would need new custom software for a new drive even if it was a fit for the front panel
CanadianMaestro
Re: bryston bcd 1
« Reply #6 on: 13 Feb 2017, 01:02 am »
Why software, Phil? I don't get it.
I thought the drive was strictly mechanical, not needing computer control.
Tiny mice with crankwheels inside.   :lol:
Ignorance is Bliss.  :green:
Phil A
Re: bryston bcd 1
« Reply #7 on: 13 Feb 2017, 01:56 am »
I vaguely remember an old post by James Tanner when the drives were discontinued and someone asking a question as to why don't they just put in another drive.  This is a very long explanation on how CD players work - https://en.wikipedia.org/wiki/CD_player   The drive from my understanding needs to be integrated into the software for decoding the disc.
CanadianMaestro
Re: bryston bcd 1
« Reply #8 on: 13 Feb 2017, 02:35 am »
That's more complex than I ever imagined. Laser positioning, track detection, etc etc   :duh:
Phil A
Re: bryston bcd 1
« Reply #9 on: 13 Feb 2017, 03:07 am »
I don't mess with anything overcomplicated.  I had a sticky drawer on an old modded Oppo BDP-83 and opened it up and believe I fixed it (as least no problems in months, although I seldom use the player as it sits in a secondary system that is used more for HT).  I once opened an Onkyo Receiver (still have it in the office system) and had a bad preamp out (solder joint).  I'd have to take off one board to get to it and I just left it alone.  It was easier in the old days, whether it was automobile engines or 2-channel audio.
