Finally some Neo 3 face plates....
0 Members and 1 Guest are viewing this topic. Read 2130 times.
Danny Richie
« on: 6 Feb 2017, 03:12 pm »
I picked up some face plates and Neo 3 pdr's. So now all N Series and OB Series kit orders can be filled.
http://gr-research.com/nserieskits.aspx
http://gr-research.com/obseries.aspx
Re: Finally some Neo 3 face plates....
« Reply #1 on: 6 Feb 2017, 06:30 pm »
Cool
Those tweeters will work in the  NX-Oticas and NX-Ottica MTM's as well  :thumb:
jay
mlundy57
« Reply #2 on: 6 Feb 2017, 06:44 pm »
Cool
jay
However, the face plates won't work with the Oticas will they? If they are the same face plates that used to come with the N and OB series, they are not not deep enough to take the place of the waveguide, correct?
Mike
Danny Richie
« Reply #3 on: 6 Feb 2017, 06:45 pm »
However, the face plates won't work with the Oticas will they? If they are the same face plates that used to come with the N and OB series they are not not deep enough to take the place of the waveguide, correct?
Mike
For the NX-Otica's and MTM-Otica's the face plate is not needed.
« Reply #4 on: 6 Feb 2017, 06:50 pm »
Mike
As Dsanny says,  not needed,   the tweeter  bolts directly to the  waveguide
jay
mlundy57
« Reply #5 on: 6 Feb 2017, 07:24 pm »
jay
I was meaning the face plate could not be used in lieu of the CNC'd waveguide. In other words someone can't use the face plate to cut their own baffles, they still need the flatpacks to build the Oticas.
Not an issue for me, I still have the two pair of MTM flatpacks I got awhile back. I'm just clarifying  the issue in case someone else was thinking about building their own cabinets.
Mike
« Reply #6 on: 6 Feb 2017, 07:40 pm »
good point Mike  , brain cramp this am , misunderstood what  you were  saying  :lol:
drmike
« Reply #7 on: 7 Feb 2017, 04:06 pm »
are the mtm flat packs still available? how much $ where can they be purchased?
thanks,
drmike
aceinc
« Reply #8 on: 7 Feb 2017, 04:20 pm »
Is the MTM - CNC wave guide superior, or just different than the Neo-3 faceplates?
Danny Richie
« Reply #9 on: 7 Feb 2017, 04:25 pm »
thanks,
drmike
Yes, Jay has some of the MTM flat packs on hand. You can call to order the whole kit with flat pack all on one order and then I take care of Jay and Don on the flat pack cost. The NX-Otica MTM kit is $1,129 plus shipping. I quoted this lower earlier and had forgotten to add the tweeters.
Or you can order flat packs now directly from Jay and the kit later.
« Last Edit: 8 Feb 2017, 02:58 am by Danny Richie »
Danny Richie
« Reply #10 on: 7 Feb 2017, 04:26 pm »
Oh yeah, that 1.5" deep wave guide allows the tweeter to play much lower.
« Reply #11 on: 7 Feb 2017, 04:26 pm »
Yes, the   flat packs for the MTM's are available, I have a few pairs in stock , can get more made if needed.  They are  $239.00 plus shipping from 98844 in approx a 50 lb box.
The wave guide is  totally different from the face plate,  for  any of the  NX seris  (Ottica, Ottica mtm, or NX-Treme) ,  the waveguide is required.
jay
