Protect your garage door from break-in!
randytsuch
« on: 2 Feb 2017, 11:32 pm »
A PSA, I accidentally found this today while looking into automatic garage door closers.
I guess its pretty easy to break into a garage door, with a coat hanger and a piece of wood.
https://www.youtube.com/watch?v=CMz1tXBVT1s
I also saw a shield on amazon for $20 to guard against this, but I'm going to make something, should be easy enough.
http://www.instructables.com/id/Prevent-Garage-Door-Break-Ins/
I have two doors to secure, so I'd rather build than buy.
Randy
Re: Protect your garage door from break-in!
« Reply #1 on: 2 Feb 2017, 11:46 pm »
Good reason not to have windows in the garage doors.  But I do have a window in the walk in door to the garage.   :(
randytsuch
« Reply #2 on: 2 Feb 2017, 11:50 pm »
My garage doors have windows, it does look nice.  And this seems easy enough to fix.
If you don't want to diy, but one of these
https://www.amazon.com/Garage-Shield-GS100-Guard-Security/dp/B0160TRIS6
Armaegis
« Reply #3 on: 2 Feb 2017, 11:53 pm »
And if the garage is connected to the house, it's also generally a good idea to have a deadbolt on the door that enters into the home from there as well.
Wayner
« Reply #4 on: 3 Feb 2017, 12:12 am »
I have an 870 Remington with a predator barrel.
Bob2
« Reply #5 on: 3 Feb 2017, 01:59 am »
+1 but my backup is a 40 cal. semi auto. Exit hole is the size of a Buick.
jpm
« Reply #6 on: 3 Feb 2017, 07:21 am »
Not very effective when you're not there to use it.  You'd be better off with a dog.
« Reply #7 on: 3 Feb 2017, 10:57 am »
We have a security system that covers the garage walk-in door, but it doesn't cover the three overhead garage doors.  OTOH maybe someone will steal a few of wifey's show rabbits that cost $2000/year to feed.   :nono:
thunderbrick
  • I'm just not right!
« Reply #8 on: 3 Feb 2017, 11:46 am »
How much do you think they can could get for a cockatiel?
mcgsxr
« Reply #9 on: 3 Feb 2017, 01:03 pm »
Sadly videos like that are part of the reason I chose a garage door with no windows when we replaced the old one last year.
I keep a very large wrench hanging by the garage entry door for personal security.  If someone shows up with a gun I will gladly show them around to take whatever they want.  Not many guns up in Canada.
randytsuch
« Reply #10 on: 3 Feb 2017, 05:45 pm »
Adding a zip tip may be a very simple, cheap solution to fix this.
It needs to be able to release in a real emergency, but be strong enough to defeat the coat hanger.
BTW, I also have a camera pointed at my driveway and garage doors, hopefully that would deter someone from breaking in like this too.
Randy
Armaegis
« Reply #11 on: 3 Feb 2017, 06:46 pm »
Sadly, videos like this also show people how to do it...  :?
