For anyone that just ordered an X-LS Encore
0 Members and 1 Guest are viewing this topic. Read 1259 times.
Danny Richie
    • http://www.gr-research.com
« on: 31 Jan 2017, 05:59 pm »
It was just discovered that there were some X-CS Encore (center channel speakers) crossovers that were boxed with the X-LS Encore crossovers. Two X-CS Encore crossovers were sent out as X-LS Encore crossovers. I don't know if any others were or not. So if you recently bought an X-LS Encore kit and your tweeters sound a little hot then check your crossovers. You might have received the X-CS Encore crossovers by mistake. If so then I'll send you new crossovers.
The X-CS crossover looks like this. And note the white dot in the box checking X-CS Encore.
The X-LS Encore crossover looks like this. Note the white dot on the X-LS EX box.
