Well, not to put words in Tomek's mouth, but the Teac with PS Audio passive preamp was virtually indescernible from the Panny 15 or 30 that he bought - so, if you like the Teac, but want the remote, and consolidated chassis, the Panny might be the one for you.
As an added "bonus" it sounds best using the digital input, so you could shelf your DAC also, or sell it to add to the budget...
IF you want to use your DAC, and really only use 1 input that matters for sound quality, the JVC F-10 might be for you - not sure how the ES-1 would handle the 4 ohm Totems - I have not tried it, since I am still happy listening to the CSS drivers, even in their primitive enclosure.
