Dual outputs of the LDRxB independently adjustable in volume?
vlumpt
Are the dual outputs of the LDRxB independently adjustable in volume?
If not, what is the best way to use a passive preamp in a 2-zone system?
tortugaranger
    • Tortuga Audio
No, they are simply dual outputs carrying the same attenuated output signal. Our current models are not suitable for 2-zone setups. To do this properly you would need 2 parallel attenuators each with its own output where you could operate them independently. Basically a pair of preamps.
vlumpt
Is there an RCA out that I could run to an integrated amplifier for the second zone?  TY
tortugaranger
    • Tortuga Audio
Yes, the LDRxB has one RCA out.
vlumpt
 :D
