PA system
ScottMayo
PA system
« on: 23 Nov 2004, 07:34 pm »
OK, asking about a paging system in audiocircle doesn't make much sense, but I figure someone around here will know where to send me.
I'd like to wire a building for public annouincement. There are already speakers and 70v transformers in place; I just need an amp. I'm having trouble finding one, though. I want:
. 70v outputs, 5 or more zones
. ability to drive one zone at a time OR all of them simultaneously
. total load (all zones at once) is about 120W. No single zone needs over 30W.
. The input is one microphone, period.
. High fidelity isn't an issue. 1%THD, 50Hz-16kHz is plenty, this won't be used for music.
. Price is an issue - looking around $200 US
I don't know why this is hard to find, but it is. Any pointers?
mcgsxr
PA system
« Reply #1 on: 23 Nov 2004, 07:39 pm »
http://www.lashen.com/vendors/csispeco/Speakers/SpeakerSelectors.asp a little above your budget, but is this the kind of thing that you are looking for?
There is a unit here, for around $430, that does most of what you ask for  - SDC-6VC/70
ScottMayo
PA system
« Reply #2 on: 23 Nov 2004, 07:52 pm »
Quote from: mcgsxr
As best I can make out, that's not an amp - that takes an amp's output and routes it to several different speakers....
