SOLD: 24-Volt Battery Supply
0 Members and 1 Guest are viewing this topic. Read 506 times.
G.Michael
« on: 10 Jan 2017, 03:50 pm »
Now SOLD.
This is a fairly simply low-tech Battery Supply, as you can see from the pics.  However, it does work just fine, and includes an on/off switch for turning the battery charger on and off.  (I added the switch and LED.)
$30 + shipping.
Included is the chassis, battery charger, and wiring harness.  Output is a 4-ft-long hardwired cable with a 2.1mm connector at the end.
Options:
--Batteries not included, unless you really want them... but that would add a lot to the shipping cost.
--The hulkin' big power supply cap, which I put in there mostly only because I already had it, also isn't included unless you really want it for a few extra $.  (Not really necessary, IMO.)
« Last Edit: 10 Jan 2017, 10:28 pm by G.Michael »
S Clark
Re: 24-Volt Battery Supply
« Reply #1 on: 10 Jan 2017, 06:51 pm »
You have a PM
