Need drivers for portable speaker
0 Members and 1 Guest are viewing this topic. Read 9590 times.
JohnR
Re: Need drivers for portable speaker
« Reply #40 on: 16 Jan 2017, 10:50 am »
Yes, let's just all go to diyaudio.com. Should I just redirect audiocircle.com to there? Would save some time.
« Reply #41 on: 16 Jan 2017, 01:16 pm »
Audio Mark, that's your clue to stop with the stupid posts and do your homework.
JohnR
« Reply #42 on: 16 Jan 2017, 02:01 pm »
Unfortunately, there is a page break between the post I was responding to and my own post. Here is the relevant posting guideline.
This is NOT what I said or meant at all.
wushuliu
« Reply #43 on: 16 Jan 2017, 03:15 pm »
 :cry:
dublin78
« Reply #44 on: 20 Jan 2017, 01:53 pm »
Hi
I have researched this extensively, and my conclusion was: Faital Pro 4fe32
  • Well reviewed
    Good sensitivity
    Good off axis performance
    Available in 4ohm, 8ohm, 16ohm
    Great price
    Will work in small box
You will not get great bass outside, so don't try, unless you want to build a boominator or similar.
There is a capacitor trick that can be used to simulate better bass if needed.
I am going to build a boombox with 4x 4FE32 (two on the front, and two on the rear).
