brief thoughts on Raspberry Pi, MoOde, Squeezebox
0 Members and 1 Guest are viewing this topic. Read 7912 times.
mfsoa
Re: brief thoughts on Raspberry Pi, MoOde, Squeezebox
« Reply #20 on: 5 Jan 2017, 01:20 am »
This would be perfect to power my three Pis and the Wyred Recovery that's on its way:
https://wyred4sound.com/products/upgrades-mods-accessories/ps-1-modular-linear-power-supply
I too found the "I" part of the upsampling equation to be important. Makes you realize how much of the sound of a dac is simply due to the filtering chosen.
I'm also interested to hear about your experience with the iFi Power.
That case is for an add-on dac HAT (Hardware Attached on Top) and not the digi+ HAT that is used to get spdif coax and optical digital out. But essentially the same. I have one and it's very nice, no comparison to the plastic junk.
jk@home
« Reply #21 on: 5 Jan 2017, 02:16 am »
Yes I got the case if one is using a DIGI+ HAT. Much better quality then the plastic one. Only gripe is they don't provide any soft feet for the unit. I used some Sorbothane "Isolate-it" feet left over from another project.
https://www.hifiberry.com/shop/cases/steel-case-for-hifiberry-digi-black/
In my system, the RP3 goes into a MiniDSP NanoDIGI, which is the crossover and EQ for the mains and subs. It also uses a similar 5 volt power supply, so I bought two identical iPowers, one for each. There was a audible improvement in the sound, in both detail and depth, most noticeable on my FLAC files.
jk@home
« Reply #22 on: 5 Jan 2017, 02:18 am »
 delete
chip
« Reply #23 on: 18 Jan 2017, 04:40 pm »
Well now I bought the Pi3 and this case https://www.hifiberry.com/shop/cases/steel-case-for-hifiberry-dac-brushed-cover-2/
I haven't had a ton of time with the HiFiBerry DAC+ Pro on the PI so hopefully I will have more time once I get the above items in.
