High End Audio/HT PC system!!
0 Members and 1 Guest are viewing this topic. Read 4445 times.
8thnerve
« on: 22 Nov 2004, 08:03 pm »
Interested in getting into an Audio PC but unsure where to start?  Here is your answer.  I have built and tested this system to be a lean, silent Audio PC platform.  I will list specifics below, but here is the most important information:
Tons of Power - This PC has a 2.4 GHz Pentium 4 processor with 533 MHz Front Side Bus and a 1MB Level 2 Cache!  With 1 GB of Dual Channel DDR PC 3200 RAM, and an Radeon 9600 Atlantis Video Card with 256 MB of DDR memory and monitor and DVI output, and an incredible ASUS motherboard that supports all the latest interfaces including SATA, RAID, AGP 8x, etc., you will never lack for speed or power.  You can run all the options you want in Foobar including upsampling, room correction, etc.  Sound good, it gets even better.  All of these components run without fans!  With upsampling turned on, the processor barely breaks a sweat using only 2% of the CPU.
Silence - This PC is as quiet as it gets.  With only 3 fans in the entire enclosure (all for case ventilation) that are rated at 9db!! a piece and are all separated from the case by silicone vibration absorbers, and the spectacular Lian Li Silent tower case, nothing is audible from a foot away.  Cooling for the processor is achieved with a Scythe heat sink that is over 6 inches tall and provides excellent fanless cooling, installed with Artic Silver heat compound.  The silence would only be possible with the Silverstone Fanless power supply, which provides 300 Watts of power from a completely fanless supply, which is also mounted to a silicone vibration absorber.  Also included are two drive silencers, which allow you to mount a 3.5 inch hard drive within a rubber suspended array to completely silence the hard drive noise.
Audio – I am also offering for sale the top of the line Lynx TWO sound card.  This card provides 2 channels of input and 6 channels of output with ASIO support.  You can use Foobar or any other audio player using the ASIO for state of the art two channel operation, and concurrently use WDM for breathtaking 6 channel output directly to your power amps and take advantage of Windows Hi-Def DVD in its full glory.  The DVI output of the Radeon graphics card supports full HDTV resolution.
If you would like to use any other sound card, simply purchase without the Lynx TWO card and insert the sound card of your choice.  The motherboard also supports high-quality digital out, so if you are using a DAC in your system, you can skip a sound card altogether, and output the audio directly to your DAC.
How can I control it? – The spectacular Viewsonic Airpanel allows you to control your system anywhere you have Wi-fi coverage.  It is a 10.4” wireless display that has a touch screen and stylus, and additional USB ports to connect a keyboard and any mouse if you prefer that over the stylus and touch screen.  Since it is a remote display, you can also surf the web, and do anything else you could do from a computer.  You can even set it up to connect to any other computer on your network, so you can start up your audio PC, and then connect to a different computer to work directly on that computer from the comfort of your listening chair.  This system also includes the docking station for the Airpanel that charges it while not in use.
What do I need to add? – The system comes complete with everything you need except hard drives and an Operating System.  Why?  Well, most people choose hard drives based on their needs for their own music library.  I suggest two hard drives, one for the operating system and software, and then a dedicated drive for your music library.  However, the motherboard supports RAID so you can set up your hard drive system however you would like.  Also required is an operating system.  To use the Airpanel, you will need at least Windows XP Professional.
So that’s it? – Yup, just put in your hard drives of choice, and run your Windows XP Professional setup and it will configure all your devices for you.  Included are all boxes for the individual components, as well as warranty cards and software.
Well, why are you selling it? - I am selling this configuration to start testing a new one, using less powerful components.  Honestly, this machine is just much better than I need it to be.  I am trying to assemble a new one with lesser components to see how inexpensive I can make one to determine its market viability.
Specifications and Cost  - Listed below are the components and costs.  As you'll see from the sale price, I am letting it go at a SUBSTANTIAL discount.  You can find the parts for less if you search hard, but not much less, and shipping will increase your costs from seperate vendors.  Also, assembly is not easy, so you get the benefit of a fully assembled and tested system!
Lian Li – PC-6070B __ $190
Intel Pentium 4 – 2.40A GHz, 533 MHz FSB, 1 MB L2 Cache __ $200
Asus P4P800 SE __ $120
Scythe NCU-2000 Heat Sink __ $65
Sapphire Radeon 9600 Atlantis – 256 MB DDR Memory – Fanless __ $150
Silverstone ST30NS Fanless 300W power supply __ $180
Samsung SH-W08 DVD+-R/RW DVD burner __ $100
Geil Dual Channel 1GB PC3200 RAM (2 x 512MB for true dual channel operation, with heat spreaders) __ $200
2 Drive Silencers __ $40
3 SilenX 80mm 9dba fans – Quietest on the market!! __ $75
Viewsonic AirPanel V110P Remote Display __ $1000
Neutrik XLR to RCA adaptors __ $50
TOTAL = $2370
Lynx TWO – B (two inputs, six outputs) __ $1000
I will sell the entire PC without the Lynx sound card for $1300!  The Lynx TWO is for sale at $750.  If both are purchased, the sound card will be installed.
The system components are all guaranteed to work perfectly.  All software is included (except of course the Operating System, Windows XP Pro recommended).  This price is for the parts listed above, I am unable to provide technical support, but all the components are supported by their manufacturers, all parts are less than 3 months old.
PICTURES:
http://www.eighthnerve.com/images/AudioPC-front.jpg">
http://www.eighthnerve.com/images/AudioPC-open.jpg">
http://www.eighthnerve.com/images/AudioPC-back.jpg">
http://www.eighthnerve.com/images/AudioPC-inside.jpg">
http://www.eighthnerve.com/images/AudioPC-fans.jpg">
http://www.eighthnerve.com/images/AudioPC-airpanel.jpg">
http://www.eighthnerve.com/images/AudioPC-airpaneldock.jpg">
Hantra
« Reply #1 on: 22 Nov 2004, 08:31 pm »
That's a bad@ss machine man.
But I don't recall your post about how it sounds.  Did I miss that?
8thnerve
« Reply #2 on: 22 Nov 2004, 08:32 pm »
Quote from: Hantra
Being a proud owner of a Lynx card yourself, you KNOW how it sounds. :-)  I am a convert.  Only PC based audio systems for me now.  Once you have heard it, there is no going back.
shokunin
« Reply #3 on: 22 Nov 2004, 08:36 pm »
Are you guys using the soundcard's analog out or just for SPDIF?  What are you thoughts on the analog output qualityof the Lynx card?
vpolineni
« Reply #4 on: 22 Nov 2004, 08:43 pm »
nathan,
  are you using the volume control on your computer or do you use a preamp?
Hantra
« Reply #5 on: 22 Nov 2004, 08:47 pm »
See man. . . if you had just posted a review, or commentary in a thread, this wouldn't have happened.  Now people are going to be clogging up your sales thread.  Or maybe that was your strategy.   :wink:
Sho, to answer your question as it pertains to my system I use the analog outputs.  And love it.  A LOT.
8thnerve
« Reply #6 on: 22 Nov 2004, 08:59 pm »
Quote from: shokunin
The analog quality is the reason I chose the Lynx card.  Honestly, the analog output is flawless.  If you were only looking for digital out, go with the Lynx AES16.  It would be hard to find a better DAC than the analog out of the Lynx for less than about 5K I would say.  And even then the improvement would be minimal.
Check out the stats on the Lynx TWO from this tester: http://www.pcavtech.com/soundcards/compare/index.htm
I can't say enough about this card, and will be using Lynx cards until I hear better.
8thnerve
« Reply #7 on: 22 Nov 2004, 09:02 pm »
Quote from: vpolineni
nathan,
I have been using the volume control in Foobar, but I upsample first to 176.4K.  You would improve the sound quality significantly with a great preamp, but even without one, the sound is incredible.  In order to use less of the volume in the PC, I made a little interface box that drops the output by 12db with a simple voltage divider, that way I was able to turn down the volume less, and retain more quality.  But if you have a great preamp, leave the volume at max and let the preamp do the work.
JoshK
« Reply #8 on: 22 Nov 2004, 09:18 pm »
question, if you don't mind.   The Lynx provide 6 channels of output, is this for MC playback or can you also use them for Triamping in 2 channel mode?  Wondering if you can use PC based digital crossover with the 6 channel output for active triamping?
Rob Babcock
« Reply #9 on: 22 Nov 2004, 09:29 pm »
The ViewSonic AirPanel thing looks pretty badass. :thumb:   Spendy, but it looks like a magnificent controller.  How long does it hold the charge before it has to dock to recharge?
Is this a one-of machine or are you looking to expand 8th Nerve into selling audio PCs?
I love the surge in PC audio.  It's really humorous that so many audiophools have always looked down their noses at computers, at least for "serious" sound quality.  Supposedly the computer is "too noisy", etc etc blah blah blah.  But you can take steps to make your PC seriously quiet, and the ability to keep many GB of music at your fingertips is awesome.  I've had a PC hooked up to the stereo for years (although not one this nice).  I'm sure this machine will be gone before I have any money (just started a new job after being oow for awhile) but it's at least a blueprint for where to go when I'm "back on my feet."
BTW, that's around $200 lower than the best price I've seen on the LynxTWO.
Jon L
You Got PM
« Reply #10 on: 22 Nov 2004, 09:31 pm »
I sent you PM.  I'll take it off your hands without the Lynx card.
How did you know I've been researching this topic.  You're right, it is possible to assemble something like this cheaper, but what a hassel..
Hantra
« Reply #11 on: 22 Nov 2004, 09:32 pm »
Quote from: JoshK
Yes, and yes.  There is software out there now that does triamping, and digital crossover.
Jon L
« Reply #12 on: 22 Nov 2004, 09:43 pm »
Quote from: 8thnerve
Oh, damn it.  I changed my mind.  I'll take the Lynx 2 card also :(
My wife is going to slaughter Me...
8thnerve
« Reply #13 on: 22 Nov 2004, 10:12 pm »
Quote from: JoshK
You can configure it however you want.  So you can easily do what you suggest.  That's why for only $250 more retail, I went for the TWO over the L22.
8thnerve
« Reply #14 on: 22 Nov 2004, 10:15 pm »
Quote from: Rob Babcock
I love the surge in PC audio.  It's really humorous that so many audiophools have always looked down their noses at computers, at least for "serious" sound quality.  Supposedly the computer is "too noisy", etc etc blah blah blah.  ...
The Airpanel is very cool.  I have never used up the battery, but I have used it for hours.
Let's just say I am investigating the possibility of such a product. ;-)
You are right about the PC noise level.  Even with this hooked up to a pair of Avantgarde DUOs (104db), the noise level was non-existant.
cjr888
« Reply #15 on: 22 Nov 2004, 10:15 pm »
Sweet setup, and nice deal, especially with the AirPanel.
Jon - You are going to be one happy person.
Hantra
« Reply #16 on: 22 Nov 2004, 10:20 pm »
Quote from: cjr888
No doubt man.  You're gonna FLIP!
Before you install XP, PM me.  I have a link to some super documents that will help optimize it for audio.
Hantra
« Reply #17 on: 22 Nov 2004, 10:50 pm »
Guys:
I thought I had posted this before, but here's the link I was telling you about.  It's good stuff from our friends at Tascam.
http://www.tascam.com/Products/US-428/W2k_XP_Optimize.pdf
8thnerve
« Reply #18 on: 23 Nov 2004, 01:50 am »
Sold.
