Passive Preamps from Jolida and Response Audio Questions
Passive Chappy
I combining two different threads from here and in the Market Place circle to ask a few questions -
1. It looks like the Jolida JD50 is has full remote control.  Does the custom Response audio unit have the same?
2. Can there be more than three inputs on either unit?
3. If there can be more than three inputs can they be remote controlled?
4. Does the JD50 only come in silver?
5. Does the JD50 have a tape loop?  It looks like it might but I can't tell.
6. Can the Alps 100K in the JD50 be changed to a 50K or 10K and still be remote controlled?
Sorry, I guess there were more than a few questions.
Thanks for your help on this.
Bill Baker
    • Musica Bella Audio
« Reply #1 on: 21 Nov 2004, 09:15 pm »
Not full remote but remote volume only with optional additional inputs/outputs available.
Our custom units can have up to six input. The JD50 appears to actually have 4 inputs, Taoe, tuner, CD, Aux.
The Jolida does have remote switching. Our unit will not.
4. Does the JD50 only come in silver? Yes
No, just a tape in. (another line level input)
 I would have to say yes, it is just a matter of changing out the volume control.
Bill Baker
« Reply #2 on: 21 Nov 2004, 09:17 pm »
Sorry, forgot to mention. I can also add a tape output to the Jolida unit. Our custom unit will also have this option.
JoshK
« Reply #3 on: 23 Nov 2004, 02:50 pm »
Here is an idea....just that so take it for what it's worth.  Instead of making another similar product to Jolida's, how about making something like I am making for myself.   The idea is this...
6 source input switch to buffer to 3 output switch, no volume control in this box.  The idea being you can add this to any preamp or tube amp with volume pot you want to gain additional features not in the preamp/amp.   The buffer is for impedance correction and IC driver.  I think I may hard wire one set of output IC's to this box to rid of one less connector and keep it really short to go right under my preamp.
There are lots of cool preamps out on the market that just don't have enough features, but with something like this it wouldn't preclude that preamp anymore.  6 sources is probably enough for most but you could always add more.  The 3 outputs are for tape/cdr output, external headphone output and preamp output.  You can go fancy and make the selector relay driven so that it could be fully remote controlled.  You can also add 3 on/off switches instead of output selector with independent buffers to make all the outputs independent of one another.   It is a very simple concept, moderately simple to build and then allows the preamp to put all its resources into the circuitry and volume control.
The reason I wouldn't put the volume in the selector is two fold.  First is simplicity and secondly it would be better off IMO in the preamp where the correct impedance of the pot can be determined and the appropriate type of VC can be made for the preamp in question.  The headphone/record out don't need volume control anyway.
Anyway, this is an idea that I am working with.  I just built my first tube preamp and for simplicity of build and to not commit too much $$ to an idea that I wasn't sure was going to work I decided on one input, one output.  I am going to build this selector for myself to couple with it.  Now I can play around with building different preamp circuits without having to bother with the inputs/outputs for the most part.   If you want a processor bypass in your preamp you just add another pair of inputs with a switch that bypasses the VC.   You can also add two pairs of outputs to your preamp as you want.  There is more room for inputs/outputs and it is much easier to customize a selector than a preamp for layout reasons.
Bill Baker
« Reply #4 on: 26 Nov 2004, 12:11 am »
Hi Josh,
  To be honest with you, since Jolida has released this ahead of schedule, I have decided not to produce our passive unit other than a custom order.
 The good news is that we are pushing our tube preamp production forward. This is something we have been working on for some time and will be full of a lot of "nostalgic" features.
  I cannot release any further info at this time but can say that it will be housed in a custom, hand build solid wood chassis by one of the best craftsman I have even come acroos. Some of the features that will be included are those which have not been seen on too many preamps in many years and some that were mentioned in your response above.
  More information will be released as details are finalized.
