Cables for Omega Super Alnico's
0 Members and 1 Guest are viewing this topic. Read 8522 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
Re: Cables for Omega Super Alnico's
« Reply #20 on: 10 Feb 2017, 03:56 am »
My Super Alnico High Output speakers came with Supra Classic 2.5. They were made sometime last year.
I had to look in my SAMs, and found the Supra Classic 2.5.  Also about a year ago.
.......Peter
Louis O
« Reply #21 on: 10 Feb 2017, 04:04 pm »
Hi Everyone,
Great posts about the cable I use inside the speakers. I want to clarify and apologize if I made a mistake explaining what cable I install.
Inside all the cabinets I use Supra Classic 2.5. I find it to be a great sounding cable.
I also get many inquiries about what to use outside of the cabinets. I always recommend Zenwave as I like it the best and for a less expensive option I recommend Supra Rondo 2.5.
Thanks again,
Louis
Louis O
« Reply #22 on: 10 Feb 2017, 04:10 pm »
Hi Roscoe65,
We got a little over a foot of snow and I'm sure you got more if you're north of me.
Back at the shop today.
Louis
DaveC113
  • ZenWaveAudio.com
« Reply #23 on: 10 Feb 2017, 05:48 pm »
Hi Louis, it's about 70 degrees right now in the Front Range of Colorado... :lol:   I was in Denver yesterday, it was mid 70's, so strange!
I've tried Supra wire, I forget exactly what model, I think it was their litz wire and not the tinned copper though... it is very good for the price!  :thumb:
roscoe65
« Reply #24 on: 10 Feb 2017, 09:50 pm »
Hi Roscoe65,
Louis
I'm 17 miles directly south of you.  We received the almost exactly one foot.
pstrisik
« Reply #25 on: 11 Feb 2017, 02:58 am »
Louis, I can't recall if you used R Compound in my SAMs & woofers.  Do you recall.  Or, if anyone knows, what does it look like/have a photo?
Thanks........Peter
Nocturne79
« Reply #26 on: 4 Apr 2017, 04:03 pm »
Hello wanted to mention another good speaker cable i found for my omegas was Cullen Cables very well priced and for me it sounds great.  Just wanted to mention another affordable cable option.
Have a great day
MarkR7
« Reply #27 on: 4 Apr 2017, 06:51 pm »
I know my SAMs (soon to be replaced by SAM HOs) really shine with the Cerious Graphene speaker cables. It was a well spent $700!
