Bryston 4B Cubed transformer buzz
Clive197
Re: Bryston 4B Cubed transformer buzz
« Reply #20 on: 7 Nov 2024, 12:30 pm »
I considered this avenue and ruled it out after test of an "IFI Audio DC Blocker - 10A" filter : presence of hum.
Also, from my internet research, it appears that the 4B3 has a DC blocker at the power input which effectively eliminates the problem. Afterwards, maybe I'm wrong?
It may not be the power amp that’s the issue, it could well be higher up the chain. Pre, Source, which is why I used the block that covers my entire system.
Speedskater
  • Kevin
« Reply #21 on: 7 Nov 2024, 12:41 pm »
Power line DC offset is seldom 24 by 7 in homes.
But it is easy to check for, by taking the amplifier to a home in a different neighborhood.
While some legacy or boutique amps have this type of problem with high AC line voltage, I don't think that a Bryston amp ever would.
Rusty Jefferson
« Reply #22 on: 7 Nov 2024, 01:04 pm »
But it is easy to check for, by taking the amplifier to a home in a different neighborhood......
In post #19 Fab77 says he tried it in 3 different houses in 3 different cities, and all 3 had the transformer buzz.
Fab77
« Reply #23 on: 7 Nov 2024, 06:03 pm »
This is not possible, the first 4B3 purchased and the second one received as a replacement are buzzing with nothing connected except the mains cable (no speaker cables or modulation cables).
This has been checked in three different places and cities (among other things, to eliminate any problems with my electrical installation).
Xinon
« Reply #24 on: 19 Oct 2025, 06:05 am »
Was there any solution to this?
I just got my Bp26/mps2 and 2,5SST 2 out of storage and transformer in both Are buzzing.
I remember them as silent when put in storage.
They are from 2011, maybe its normal with this old hifi?
Still have my BDA 1 in use daily from 2009, its dead silent and still sounds better than newer dacs Ive tried :thumb:
Bernie_
« Reply #25 on: 11 Jun 2026, 06:02 am »
Hi,
I've recently bought a 4b3 made this year and both the orginal and replacement unit have had a mechanical transformer buzz. The orginal unit was so bad that you could hear it walking past the door to the room. The replacement unit is quieter but I can still hear the hum sitting 3 metres away.
Is this a known issue with the 4b3?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #26 on: 25 Jun 2026, 07:23 pm »
Should be quite - where are you located?
james
