0 Members and 1 Guest are viewing this topic. Read 13467 times.
Reason: main amp is now only outputting 70Hz and above. It does not contain anything below 70Hz.....which is what the sub needs!This was kind of my next question. Since the amp is now only getting 70Hz signals and above, does this also make the amp run more efficient? Because it doesn't have to produce the lower frequencies?
I think I understand what you're wanting to do...Option #1Pre --> 70Hz In-line Crossover --> Amp --> Speaker Cables to full-range speakers receiving 70 Hz+ --> Speaker Cable to speaker level input on 'sub' receiving 70 Hz+ w/ Low-pass set to 150 Mhz --> Pre-amp LFE or 2nd Pre-amp output --> Big sub w/ Low-pass crossover set to ~70 HzOption #2Pre-amp Output #1 --> 70Hz In-line Crossover --> Amp --> Speaker Cables to full-range speakers receiving 70 Hz+Pre-amp Output #2 --> Stereo RCA Cables --> Big Sub RCA Inputs --> Big Sub Low-pass set to play 70Hz and belowBig Sub Pre-amp Output sending 70 Hz+ --> Stereo RCA Cables --> Small Sub RCA Inputs --> Low-pass set to 150 MHz
My buddy is high passing his Super Alnico Monitors with these Harrison gizmos, placed line level between pre and amp. He tried both the 50Hz and 70Hz, and prefers the 70Hz in his rig.He says they work like a charm with no detectable sonic degradation. By removing the lows, he can play the SAMs louder with less distortion, greater purity, and a big holographic soundfield. He runs his 2nd preamp output into his Gallo sub to fill in the lower range. Tells me it blends perfectly, with no sub localization.Says that with this setup, he's getting best sound he's ever had. I haven't personally heard his rig, but he's very experienced with lots of good gear, so I'd tend to believe him.
So I want to use my Omega's like this. Main driver 70Hz-20KOmega deep 8- 70-120Subwoofer 60Hz on downThis would cover the entire audio frequency spectrum and maybe get fulll efficiency out of every component. I essentially want to use the Omega 8 as a mid bass module, sort of like what HSU used to have.
...... Louis has speaker level in and out that does high pass. Run your mains' speaker cables to the deep 8, then from the deep 8 to the monitor. Set the crossover on the deep 8 to the frequency of your choosing. ..........Disadvantage is if this offends your purist approach, assuming you have one that is. You would be adding a crossover at speaker level which is counter to the single driver philosophy. But doesn't cost anything to try and you can see how it sounds. The gain from lowering the mains' workload may outweigh any loss from running through the sub's crossover.
My guess is.....Even though you are doubling up your RS5 driver, if you eliminate subs you are gonna miss them. Just based on my personal experience of listening to a coupla different Omega models both with and without subs, and talking to a few guys that have done the same.....including SAM owners.
I did get a 50 and 70 Hz pair of crossovers from Harrison Labs. Initial impressions of the 50's after very limited listening last night was that the low end sounded a bit weak, but the RTA in the Audio Tools app doesn't reflect that, so I'll do some more listening with and without and see.
Super 7XRS MK2 w/ a front-firing DeepOmega8.It seemed to thin out the impact of the lower end just enough to matter. I expect that the volume of my space is too large for a single DeepOmega8 on its own (~20'x22'x8'), but it's definitely more than adequate when used in conjunction with the Super7's running full-range. When I have some time, I'll try again with the DeepOmega crossed over closer to 50Hz.
