SUPERCLOCK 3 IS HERE! HEAR WHAT YOUR MISSING IN YOUR DIGITAL
0 Members and 1 Guest are viewing this topic. Read 3795 times.
ASi_TEK
  • NO LIMITS!!!
    • www.asi-tek.com
Reference Audio Mods is proud to premiere the exceptional Superclock 3 from Audiocom International.
The SuperClock 3 is an aftermarket reference low-jitter clock, guarunteed to improve any CD/DVD/SACD player performance dramatically or your money back!!
Why upgrade the Clocking Circuitry in your Digtal Source or DAC???
In more than 90 - 95% of CD players (SACD, DVD & DVD-A ) the master clock whose function is to generate a low jitter square wave, is a simple passive circuit which uses the input of an inverter, typically 74HCU04 and consists of a quartz crystal, 2x low value capacitors in series fixed to ground, and 1-2 resistors. The remaining 5 - 10% of players are slightly better and use a clock oscillator module which uses its own inverter and has a better temperature stability, or use a single discrete transistor oscillator circuit. This is true of machines costing $500- to $20,000- regardless of manufacturer or model.
None of these methods are suitable and all produce high losses of resolution (high jitter and error rates)for both audio and video recording and playback which closes down soundstaging, focus, detail, micro/macro dynamics and liveliness. The Superclock 3 completely fixes all these problems, leaving the user with a live breathtaking experience.
THERE IS SO MUCH MORE MUSIC TO BE HAD, THE SUPERCLOCK 3 DELIVERS IT LIKE NEVER BEFORE!!
Audiocom SuperClock 3 $295 ea (Any typical Frequency available)
Built from many years of experience the new SC3 has reached a level that far surpasses any other aftermarket clock we have heard...and yes, even the Superclock 2! The SC3 has been completely redesigned
using only state of the art components meticulously hand picked for there sound. RAM has directly compared the SC3 to the SC2 and the results are truly phenomenal!
Improvements we hear:
First and foremost is the incredible sense of presence. It is as if music is now "in the room" or NOT locked onto the speaker. There is now a complete lack of strain and compression which is now so very noticeable without the SC3.
Macrodynamics are greatly improved over the SC2. The SC3 provides dynamics much closer to live music such as in the "pop" of a snare drum or the "pluck" of a bass guitar.
Resolution. We simply hear more musical information. Inner detail and imaging are now very prominent. The musical presentation now sits on a much larger lifelike stage.
Bass slam comes through with a sense of realism. We descibe the bass as sounding very "open" of lack of strain.
Vocals are much cleaner and natural sounding, again providing that "in the room" sound. Uncanny!
The High frequency information comes through with delicacy and tonal color. Bells in certain tracks were simply smeared with the SC2. Using the SC3 we hear absolute clarity,extension, and openess.
Audiocom SuperClock 3 Power Supply Unit $295 ea
We also offer a dedicated power supply unit to power the new SuperClock 3. This makes a nice noticabel difference in the sound, offering more neutrality and resolution in the soundstage.
(If Reference Audio Mods installs this for you we modify the power supply further for even better sound!)
How Much and Where to Buy????
The Audiocom Superclock 3 units are $295 ea. and can be purchased on our website at www.referenceaudiomods.com
WE HIGHLY RECOMMEND A PROFESSIONAL INSTALLATION OF THIS PRODUCT BY US.
How and Where Do I Get This Installed So I can Start Hearing the Superlock 3 Difference???
LIMITED TIME OFFER!!!
We are offering FREE INSTALLATION of the Superclock 3 and the Superclock 3 Power Supply.
The Price (INSTALLED) by us at our RAM EAST location:
Audiocom SuperClock 3 PSU (Modified) $295
While your unit is at our modification location, we Highly Recommend doing other modifications to your units for even more extreme performance that will exceed your expectations!!!
We use cutting edge products in our mods such as:
-Rubycon ZA/ZL capacitors (which offer higher ripple current and lower impedences than all other caps)
-Tube-like sounding Stealth Diodes for unsurpassed performance for use in power supplies
-High Speed Audiocom Q-power or Super Regulators for lowest noise possible for more slam and less background noise
-Exotic Jensen 4-Pole Capacitors for Power Supply application to delvier more of a natural/neutral tonality
-Audio Consulting Silver Wire and Copper or Silver Wire Output Stage Transformers and power supply transformers for unsurpassed Energy Transfer and the highest level of resolution/dynamics possible
-WBT NextGen (Eddy Current Free Design) RCA female jacks for an unbelievable thrilling sonic experience.
-and many many more!!!
Please check out our website at www.referenceaudiomods.com
We offer Discussion Forums to ask questions and learn about our high performance mods and products.
We can be reached via email at [email protected] for modification inquires or by phone at 586-944-5611.
Thanks and we look forward to assisting you in the path of the best sound available today!
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #1 on: 19 Nov 2004, 02:55 am »
is there a way to lift the digital signal right after the SC3 to run it to a digital amp?
Could you mod a Pioneer 578a so it puts out it's DVDA/SACD/
CD/DVD signal via a coaxial digital output?
Lost81
« Reply #2 on: 19 Nov 2004, 03:42 pm »
Quote from: ASi_TEK
-Rubycon ZA/ZL capacitors (which offer higher ripple current and lower impedences than all other caps)...
Yes, I heard a lot about these capacitors.
In fact, they are spec'ed on a lot of the new high-performance motherboards.
Check out the specs on this chart!
(Source)
Very impressive specs next to the Panasonic FC (which is already a rather good capacitor).
Another chart:
I think this chart shows how the ZA approaches the impedence of OSCONs:
Anyone know where we can download the ESR / Impedence data for Rubycon Black Gates?
-Lost81
ASi_TEK
  • NO LIMITS!!!
    • www.asi-tek.com
« Reply #3 on: 20 Nov 2004, 03:17 am »
Hi Lost81,
There are no charts for the Blackgates, are they are being discontinued. The ZA/ZL sounds far superior to even the best N series blackgates. They offer such a more open and live sound where the BG sounded closed downa and slower. The BG is ALOT better than stock caps, and are smooth sounding but not the end all in audio capacitors.
