Anti virus recommendation
Re: Anti virus recommendation
« Reply #20 on: 29 Dec 2016, 07:54 pm »
I had removed McAfee av and are using Wdef, seems W10 is a bit faster.
Wind Chaser
« Reply #21 on: 29 Dec 2016, 08:38 pm »
I've had Norton, then Avast and now I'm using Kaspersky.
IMO, they all pretty much do the same thing equally well.
« Reply #22 on: 29 Dec 2016, 10:01 pm »
Iam using Wdef why its free, others are paid software.
skunark
« Reply #23 on: 29 Dec 2016, 11:23 pm »
Windows defender..
Don't install java of flash....
Doublej
« Reply #24 on: 30 Dec 2016, 12:37 am »
And install Ad Block Plus or a similar ad blocker. It doesn't stop everything but it keeps 90+% of the bad stuff from getting near your machine.
ctviggen
« Reply #25 on: 30 Dec 2016, 01:25 am »
I've had bitdefender (requires downloading program from cloud, which I find onerous; I couldn't get it to download to a few computers), Kaspersky (which I find way too intrusive and time consuming) and Eset.  I liked Eset the best in terms of use.
I've installed both Java (MUST have it) and Flash on all my machines (6).
