You can always buy from Tire Rack and have them ship to you, so you can use your chosen installer. Generally speaking, with the low overhead and large volume involved, they are cheaper. For me, Blizzak winter tires from Tire Rack was $83 cheaper than buying locally. In the case of winter tires you have two options: use your own wheels/pressure sensors and remount twice yearly; or buy extra steel wheels/pressure sensors and just swap twice yearly (plus with care you can down size the wheel/tire size to save some money). In my case it would be $400 more to go with the second option, but $80/year cheaper (plus my labor to do the swaps). One of my local dealers had steel wheels/pressure sensors, the other didn't have steel wheels.
I also had TPMS installed - can't see any rationale behind not having a device that can improve fuel performance and safety
