HDTV display tuning for PC
0 Members and 1 Guest are viewing this topic. Read 1021 times.
Doublej
« on: 5 Nov 2016, 12:56 am »
Any tips for optimizing an HDTV display for use with a computer?
At work in a number of conference rooms we have a Samsung  HDTVs (typically) and monitors that are being driven by PCs. They all look a bit washed out like the display is being over driven but I can't seem to tame them using the PC graphics card controls. Is that just the way it is or are there screen optimization secrets I don't know about.
JRace
  • Greetings one and Everyone!
Re: HDTV display tuning for PC
« Reply #1 on: 7 Nov 2016, 04:04 pm »
Focus on the TVs picture options/tuning and not the PC.
There is far more you can do in the TV itself.
For the PC side you can try this:
http://www.digitaltrends.com/computing/how-to-calibrate-your-monitor/2/
