DAC 10 volume over 20~25 extremely loud.
resovia
« on: 10 Oct 2016, 06:30 pm »
Asking DAC 10 owners what are your volume settings for normal listening levels?
I cannot go over 20~25 depends on the gain (LL/HL) settings, it just gets too loud. Currently have 4 amps including ST 10 and behavior is the same with all of them.
agdev01
Re: DAC 10 volume over 20~25 extremely loud.
« Reply #1 on: 10 Oct 2016, 07:16 pm »
Try using the RCA outputs along with the LL/LH setting versus the xlr if you aren't already.  That will put it at a 2v output.
rustydoglim
« Reply #2 on: 10 Oct 2016, 07:50 pm »
DAC-10H can drive high efficiency speakers.
HPA-9 too.
resovia
« Reply #3 on: 10 Oct 2016, 08:11 pm »
My speakers are 88dB
rustydoglim
« Reply #4 on: 10 Oct 2016, 08:14 pm »
I think the headphone amp can only drive speakers in the mid 90s dB and above, without using a power amp.
John Casler
« Reply #5 on: 10 Oct 2016, 08:24 pm »
I have used several DAC-10 and DAC10H and the readout is usually around 35-55db.  This basically tells you nothing because I have not measured the actual db output at the listening position.  My best guess would 65-75 db average.
This is with a standard (fixed) 2v OPPO Player output, and 90db speakers.
Also it is set on HL and running XLR outputs to an ST-10 or K-38
So the elements that i might think could affect this are:
1) Source Signal Strength/Output
2) Using RCA or XLR outputs
3) Amp Sensitivity
4) Amp Gain
5) Speaker Sensitivity and on axis convergence
6) Near or Far Field listening position
7) Abundance or lack of Acoustic Treatment
resovia
« Reply #6 on: 10 Oct 2016, 08:49 pm »
I am using Win. PC (jRiver) over USB/OPTICAL >> DAC >> ST 10 >> 88dB speakers. Initially from factory DAC's volume is set to 50. When I installed and turned on the DAC for the first time I though I blew my speakers. Several seconds of panic before I unplugged power cord from the wall. My wife hates me for that she was in the room.
I am discussing high gain settings with person from nuPrime support and it seems the DAC is design that way.
jonbee
« Reply #7 on: 10 Oct 2016, 09:40 pm »
I use the LL settings, running coax digital from my PC music server or Oppo BDP-93. XLR from 10H-> ST10, 91 DB sensitive speakers. Background volume is at 15 or so, very loud is about 55. Range works just fine for me in normal use.
Perhaps the default OOOB setting might be moved down a bit.
« Last Edit: 10 Oct 2016, 10:55 pm by jonbee »
SFDude
« Reply #8 on: 11 Nov 2016, 03:27 am »
I've just received the DAC-10 and put it into my system. I'm using a MBP via USB and playing a bunch of files off my NAS or via Tidal. It is connected to a pair of ST-9s via XLRs and driving Spatial M3 Turbo S speakers.
I can't turn it beyond 20 before it gets overly loud.  :oops:
I'm using LL settings as well.
rustydoglim
« Reply #9 on: 11 Nov 2016, 08:49 pm »
Use RCA. You have too much gain in the setup with XLR.
SFDude
« Reply #10 on: 21 Nov 2016, 12:30 am »
Switched to RCAs and it is not a whole lot different to the XLRs. Good listening volume at 15. 20 is about the max I can take it without overpowering the room it's in (12' x 13').
Speakers are 94dB sensitive.
rustydoglim
« Reply #11 on: 24 Nov 2016, 10:37 pm »
Probably it is the efficiency of your speaker and the input voltage.
The volume control is switched resistor/digital volume (inside the DAC), so it doesn't matter where is your max volume.
