So What is the Mirror For?
0 Members and 1 Guest are viewing this topic. Read 3154 times.
sebrof
« on: 5 Oct 2016, 01:37 am »
I have always wondered what the mirror under the cartridge is for on the Amadeus.
Seems a bit low for azimuth adjust, the arm is at a much different angle than while playing.
Too far away from the stylus for a good look at the stylus to see if it's gunked up.
I use it to check my mustache for crumbs while cuing up a record ;)
ADiG
Re: So What is the Mirror For?
« Reply #1 on: 5 Oct 2016, 06:28 am »
The mirror of the Amadeus is an aesthetic embellishment, makes me crazy!  :singing: :singing:
« Last Edit: 5 Oct 2016, 09:16 am by ADiG »
G E
« Reply #2 on: 8 Oct 2016, 01:33 am »
How did you get yours all shined up so nice?
ADiG
« Reply #3 on: 8 Oct 2016, 07:25 am »
Wipe with paper towel or soft, damp cloth, breathed.
It can also be used to spray furniture polish, not to scratch the surface.
In short, to be treated as a spectacle lens. :wink:
G E
« Reply #4 on: 8 Oct 2016, 12:31 pm »
I'll try cleaning and buffing it with lense cleaner solution and microfiber cloth. My Amadeus mirror is slightly spottled, it was a dealer demo unit I picked up when the current version came out.
