**SOLD FS: Audio Research VT 100 Mk III Amplifier SOLD**
0 Members and 1 Guest are viewing this topic. Read 4135 times.
pgbcincy
New: $6495
Ask: SOLD Delivered (includes shipping in continental US and PayPal fee) (2.9%)  (includes new complete set of tubes - $400; < 20 hours)
Pay Method:  Paypal
Ships from: 45202
Cosmetic: 7/10; small nick on top left side of faceplate. Please zoom in on pic.
Specs:
•   Power output: 100 watts per channel continuous from 20Hz to 20kHz. Approximate power at clipping is 120 watts.
•   THD: 1kHz total harmonic distortion (typically .3% at 100 watts and below, .03% at 1 watt).
•   Power bandwidth: 12Hz to 60kHz (-3dB points at 1 watt)
•   Frequency response: 1hZ to 80khZ (-3dB at 1 watt)
•   Input sensitivity: 1.7V RMS (balanced or SE) for rated output (24.3 dB gain balanced into 8 ohms)
•   Input impedance: 200k ohms balanced, 100 ohms single-ended
•   Output taps: 8 ohms, 4 ohms.
•   Overall negative feedback: 15dB
•   Slew rate: 8 volts/microsecond
•   Rise time: 4 microseconds
•   Hum & noise: less than 0.2mV RMS 103dB below rated output (IHF weighted, input shorted)
•   Power supply energy: approximately 540 joules
•   Power requirements: 105-125 AC 60Hz (210-250 VAC 50 Hz); 650 watts at rated output, 800 watts maximum, 440 watts at idle
•   Tubes required: (4) matched pair 6550C; (4) 6H30
•   Weight: 66 lbs.; 83 lbs. shipping
•   19" (48.3 cm) W x 8.75" (22.2 cm) H x 19.5" (49.5 cm) D. Handles extend 1.5" (3.8 cm)
Reason for sale:  Spring Audio Cleaning; Speaker change
Notes:  2nd owner
Sonically and functional perfect
Manual and original box
Purchased new tube set for resale (4 matched pairs) Sovtek 6550WE power output, (4) Russian 6H30Pi Platinum Grade, Cryogenically Treated – Upscale Audio.  Tubes are biased at 65mV and ready to go.
Used this with Genesis APM-1 which was voiced with the VTM 200.  Also used with the ACR LS25 Mk II preamp which was a great combination.   Wonderful depth and width soundstaging, smooth yet inner detail transients revealed.
Any questions, let me know.
Thx!  Paul
From Audio Research: Since the spring of 1996 the VT100 established itself as the benchmark amplifier in its price range. Accolades from the press and music lovers grew even louder with the 1998 introduction of the MKII because of its improved dynamic swing, more refined performance, and ability to drive so many "difficult" loudspeakers which normally could not be used with other vacuum-tube amplifiers. Well, the VT100 in MKIII iteration will shake up the audio world once again and assure that it remains the best-selling vacuum tube amplifier in the world.
The advancements derived from the development of the remarkable VTM200 monoblocks have been so large that we feel compelled to integrate many of them into the VT100 through a MKIII update. This is a major step forward in sonics, reliability, and ease of use.
Externally, the only changes are to the back panel where we have added two welcome features. There is now a Balanced/Single-Ended switch, eliminating the need for shorting links in the XLR balanced connectors when using single-ended RCA cables. We have also incorporated a (dual in/out) 12V power on/off trigger for remote or custom installation purposes. (The soft-start surge-control feature of the VT100MKII power circuits is preserved.) Now you can link the VT100MKIII to the LS25MKII for remote operation!
Internally, the circuitry of the VT100MKIII is derived from the VTM200. Like its more powerful sibling, the MKIII's input stage utilizes direct-coupled JFETS for ultra low noise, and is followed by a 6H30 driver/gain stage, capacitor coupled to a 6H30 follower, driving two matched pairs of 6550C output tubes per channel. The conservative 6H30 driver-follower circuit will help prolong the life of the 6550Cs, and the 6H30 is rated to handle higher currents than the previously used 6922, so it has lots of safety margin for even better reliability. (The 6H30 twin triode is a Russian military tube in current production, with an estimated service life of up to 10,000 hours.) There are now four internal bias adjustments-up from the previous two- to allow more accurate DC balance adjustments for the output tubes. The line fuse has been increased to a 7 amp in 120V units (6.3 amp in high voltage units), allowing the MKIII to handle musical dynamics with greater ease.
Simply put, the VT100MKIII is a major sonic advance. As the original VT100 was greatly improved upon by the MKII, the MKIII eclipses it again by the same margin. Resolution and dynamics are startlingly better: suddenly you can pick out each individual voice in a choir, you can hear the air gently modulated by a hundred diaphragms singing in unison in a great cathedral. Small and large details stand out in bolder relief, tightly focused, wonderfully holographic. Bass is tighter and more dynamic. It sounds as though the power has been increased, with a more effortless quality. The MKIII is easily recognized as having been borne of the VTM200. Lastly, the single-ended RCA input is almost indistinguishable sonically from the balanced-XLR input.
Link:
http://www.arcdb.ws/VT100/VT100.html
« Last Edit: 15 Dec 2016, 09:14 pm by pgbcincy »
OzarkTom
Re: Audio Research VT 100 Mk III Amplifier
« Reply #1 on: 10 Sep 2016, 12:38 am »
A glowing review from Positive feedback. :thumb:
http://www.positive-feedback.com/Issue14/arcvt100.htm
pgbcincy
« Reply #2 on: 10 Sep 2016, 02:42 am »
Thank you Tom!  I was looking for that...   :duh:
pgbcincy
Re: FS: Audio Research VT 100 Mk III Amplifier
« Reply #3 on: 3 Dec 2016, 07:45 pm »
bump
