GTI is a turbo car. from Mk 4 onward 1.8T then the 2.0T from Mk5 to present. Yeah, the early variants were NA.All replies pretty spot on. You can get some big power gains on turbo cars w/ ECM refresh, though it generally means running higher octane fuel.Yeah most the HP gains claimed by the manufacturers of CAI & Catbacks are hype.As stated you might get 10-15HP at crank for an outlay of $1500.But as crazy audiophiles we spend a lot of money on dubious things like 'magic' wire. So maybe 'magic' piping on a car makes sense. I wrestled w/ this very question for my VW GSW/JSW 2.5. Probably not worth the money.Now by front strut bar, did you mean front strut tower brace, or front sway bar? Strut brace would be good if you are really pushing car hard. If you meant sway bar, I would ask how does the car handle now? If it seems to understeer, then going to a stiffer rear sway bar can help w/ that.All that being said, I've read that Ingen makes a fine product, especially for Japanese cars, and they are somewhat less expensive that other. The sell the type that does not locate the intake down low where you have to worry about hydrolocking. I understand the urge to upgrade. I've got a box full of suspension parts waiting to go under my wagon, just haven't had time to install.
Ok, I think you guys have convinced me to not get a CAI. I might still get the strut brace thing since its cheap enough.So I'll look into getting WRX Limited or STI Limited in the next year or two. That should give me time to learn to drive a stick.
Do not underestimate the value of low unsprung weight per corner. It will affect handling more than changes to the front sway, for example, and at the same time, any benefits a front sway adds will be enhanced with low unsprung weight. Run, don't walk, from any aftermarket wheel that does not list the weight in the size you are considering. That is not a guideline, that is a Directive From Above. No exceptions. Do not buy any wheel/tire combo that is not lighter than the OEM figures.Also determine the weight of the tire you can fit to any wheel, and don't forget the weight of lug nuts. DO NOT compromise strength when selecting lug nuts, but do choose lighter variants. Also the valve stem can be lighter which makes balance and handling improvements.
Most "Cold Air Intakes" don't suck cold air and absolutely have no Ram Air effect, and in some cases they remove the factory Helmholtz Resonator effect that can improve low-to-midrange torque that small displacement motors tend to lack. You need to use a manometer or at least wool tufts to find out where your low pressure intake area is ... it is NOT always at the windshield/hood interface but critically dependent on the shape of the front third of the vehicle. On almost every vehicle the area where the front license plate normally resides is the best spot for intake air (have something to keep water out or allow it to drain as this is close to the road surface and vehicles in front of you will spray water there more than higher up).The front strut brace is helpful if:It is actually rigid rather than decorativeYou have a MacPherson Strut front suspension geometry. It does help with a front Shock geometry but much, much less so and may not be cost effective in that case.Sway bars significantly affect handling. The stiffness and to a lesser extent weight (solid vs tubular) are important factors. You should consider changes to the rear suspension with regard to sway bars (some cars have none in the rear, some cars benefit from removing a rear sway bar, others by stiffening it) in concert with changes to the front sway. Any changes to sway bars will affect the car's tendency with regard to oversteer/understeer, so the first thing to do is decide which tendency at the limit you prefer. FWD typically will understeer but there could be a transition point which might be abrupt and difficult to correct for. None the less a sway bar change will move the handling one way or the other, even if a FWD vehicle that will always understeer regardless, you have an opportunity to make it understeer less or more, as the case may be.In some cars you can also add a rear bar to stiffen the MacPherson struts or Shock mount towers. Are the towers visible from inside the trunk in your car?Do not underestimate the value of low unsprung weight per corner. It will affect handling more than changes to the front sway, for example, and at the same time, any benefits a front sway adds will be enhanced with low unsprung weight. Run, don't walk, from any aftermarket wheel that does not list the weight in the size you are considering. That is not a guideline, that is a Directive From Above. No exceptions. Do not buy any wheel/tire combo that is not lighter than the OEM figures.Also determine the weight of the tire you can fit to any wheel, and don't forget the weight of lug nuts. DO NOT compromise strength when selecting lug nuts, but do choose lighter variants. Also the valve stem can be lighter which makes balance and handling improvements.After the wheel / tire / lugnuts / valve stem weight, you can move to aftermarket brake calipers or two-piece brake rotors. There will typically be perhaps 6+ pounds of unsprung weight you can remove there for an import car. Check out the OEM calipers you may be able to pick up cheaply from a wrecker that were offered on high performance variants of your car or interchange with your geometry. Buy good (but street, not race type) brake pads.Any bolt-on suspension / frame braces that were offered for your make / model but were not installed on your option level should be added if they exist.You should replace any bushings involved in any suspension work you do, but perhaps consider if you are willing to put in a whole-car poly bushing kit ... they are a lot of work to install. They will add noise and stiffen everything, making the ride less comfortable. People will always tell you to go poly but you may find simply replacing the OEM rubber bushings offer enough improvement (they are a wear item) without affecting Noise Vibration Handling (NVH) as much so you still have a comfortable ride for the wife & kids to suffer in, and for a daily driver.
Now, don't get me wrong, there's good stuff among the chaff, but it amazes me sometimes that people will disregard the considerable engineering that goes into making an automobile and substitute hearsay and BS they read on web forums.
I'm not amazed because that kind of thinking isn't limited to the automotive world ..... you could easily replace "audio components" for "an automobile" in the above sentence.
True dat! It occurred to me as I wrote it that's not a new phenomenon...just a different arena.
