Nuprime UDSD, noise while a track is playing in the DSD format (Win 7 64bit)
Yoja
Hello
In general, the problem is described in the topic title.
I had connected and configure the DAC as it is written in the instructions.
Foobar 2000 was installed  (version 1.3.11), sacd plug-in was downloaded from the link, in the output settings of foobar - DSD asio nourime ASIO driver.
When the DSD track is playing - a lot of noise! Almost dont hear the music. But if in sasd plugin choose PSM instead of dsd - everything is ok (no noise).
Tell me what to do to fix it?
stanleysg
If you have not gotten any response, You might want to post this inside the nuprime audio circle instead
http://www.audiocircle.com/index.php?board=199.0
rustydoglim
    • www.nuprimeaudio.com
I have encountered problem with corrupted DSD file. Please also try different DSD files.
There is a good instruction here posted by user "Jye75"
http://www.head-fi.org/t/765642/review-nuprime-udsd/30
brooklyn
