0 Members and 1 Guest are viewing this topic. Read 11117 times.
It's a chip amp. Curious about that. Can a little chip really deliver 50W like big MOSFET?If so, one of these and a Transcendent Grounded Grid Preamp and you've got a complete cheap & cheerful amp rig for < $1K.In any event, glad to see any audio kit on the market. I built my first two audio systems (Dyna and Hafler) and it was a lot of fun. Maybe they'd consider doing a headphone amp?
Kits? You haven't looked hard enough . There is an entire world of diyaudio at diyaudio.com Come on over, the water is warm Yes, the LM3886 can deliver about 40-45 watts into 8 ohms. If you use a regulated supply, then you can push a few more watts, as the Akitika unit does. Typically about 60-65 watts into 4 ohms. Not for 2 ohm loads as the the chip is current limited to 7 amps. From a design standpoint of a chip amp, the GT-101 is "ok."For more diy and kits, check out this thread here on AC: http://www.audiocircle.com/index.php?topic=92116.0Nice build tipatina, enjoy Best,Anand.
