0 Members and 1 Guest are viewing this topic. Read 9256 times.
Audioengine A2+ sell for $250/pair with amps and DAC, and are much smaller with no DIY required. So the kit price would have to come down to interest me.To me part of the appeal of the whole concept is to use the simply/rough blocks.I'm sure some snap together connectors could be used to move the binding posts to the back.BTW, cinder block is available as an "O" versus the typical "8" internal shape.Stone (granite/marble) cabinets would be very heavy, subject to cracking/chipping/breaking, and extremely sonically reflective (would need to be lined with lots of damping material). Some manufacturers have used synthetic stone (Norh, and Green Mountain to name two off the top of my head).
Have raw materials been "audiophile" approved?
Of course it has! That is a high density silica aggregate with random particle orientation for optimal dispersion of vibrational energy, and formed into a mathematically ideal dual chambered configuration to provide both high compressive strength and modulus as well as large area moment of inertia without adding unnecessary bulk. This speaker is further formed into a composite by compression between two boards composed of natural plant fibers hardened through biological processes, and secured in place with extruded metal alloy.
You really should be in marketing, if you aren't already!
