Hey guys, thanks for not burning me at the stake for my comments....these are exactly the kind of responses I hoped to hear back.
So, if I can summarize some of the thoughts expressed so far about tubes:
* Image depth (something I am not well attuned to or have been listening to too much non-tube gear) is superior; dynamics and bass control is
most often lacking
* Synergy, as with so much of this hobby, is critical.
* Higher sensitivity, higher impedance speakers are key to getting synergy issue right (that would cerrtainly answer why ribbon pairing seems the worst tandem of all I have heard)
* One needs to prepare to spend $2 K+ for a good tube amplification component to 'hear' things in the right perspective
Heavystarch - Yep, I've attended CES/T.H.E. (audioengr and I met there) several times, ditto Stereophile Show (when I lived on East Coast), worked in an audio store 20 years ago (part time) and have had one or two locals dealers in the past 20 years that have let me hear a range of products in their showrooms for extended periods.
As an aside, do those autoformers really work?...I have read some things about Paul Speltz's autoformers.
I know I have not heard the much acclaimed Butler, nor (I think) hybrid designs from Van Alstine, Counterpoint, Anthem, Musical Fidelity, others. Perhaps that would be a more proper toe-'n-the-water approach for the future.
I am receptive to understanding that the mind can play tricks on you and tamper with my rationality/neutrality on a subject. I think in more than one instance hearing all-tube gear (some at stratospheric pricing) was that I looked at the gear, made note of how large it was, that it needed room to breathe and the fact that it is not rack mountable, etc, etc.....and reality set in; no matter how much the sound was appealling, it would never fit in my small listening room (never bigger than 12 x 15 in 20 years and a few houses). So, I may have turned off and scoffed at the sound before I really gave it a chance. Perhaps I'd best lighten up and listen instead of rationalizing.
I have swapped tubes in my Dynaco's and found that was a losing proposition mostly. I ended up liking the Sovtek 6922's in the linestage (of my PAS-4), with a mortite 'hat' and Herbie's tube dampers on them over some pricier NOS Russian 6H23's (from Upscale Audio....too damn plumpy all around I found), Phillips JAN and a couple others. My preferred configuration made it sound like SS, but not as good as good SS. But, I think it may be the platform (PAS-4) I started with was flawed to begin with...as it was indeed oneof those $600 specials.
Hell, I even tried old Telefunken's 12ax7's in phono and didn't like that either. Again, maybe the messenger needed to be shot; not the message
