0 Members and 2 Guests are viewing this topic. Read 18470 times.
I use that model Tripp lite. I have my doubts as to whether it can do what it says it can do, but it's better than most at a reasonable cost.Doc
Definitely go SurgeX, Zero Surge or Brick Wall. They won't wear out or dump energy to ground like MOV based surge protectors. If you want them cheaper get them used, I wouldn't consider any other solution, as it's far inferior to the Zero Surge patented technology.
Thanks but do you have some models you recommend? I can see using a powerstrip or so plugged into one of these to give more outlets. That should be fine, no?T
I'd avoid MOVs entirely, most powerstrips have them. Any model would be fine, but I'd go for a 20 amp model with enough outlets for all your components.
20A models will likely have a 20A male plug. Thus most are screwed with this.
I'd go for a used SurgeX over a new Zero Surge though, the SurgeX has other features that are worthwhile imo.
No matter which model you get you should cut off the molded AC plug, even if it's replaced with the cheapest model you can find at home depot the wire clamps are far better than molded plugs.
Huh?Why? What is that going to do for you?
If it's not broke don't fix it.It's trickier to replace a heavy cord plug, than some realize.
No matter which model you get you should cut off the molded AC plug, even if it's replaced with the cheapest model you can find at home depot the wire clamps are far better than molded plugs. I'd go for a used SurgeX over a new Zero Surge though, the SurgeX has other features that are worthwhile imo.
I use the tripp lite isobar ultra, built like a tank, very basic (in a good way).I also use and really like the APC G5blk. It provides some nice features, like a display to check line voltage, tons of indicator leds that can be turned off, and a programmable power on/off sequence for the outlets. Theres also a ground lug in tge back to help with ground loops i think.
