DVA101
0 Members and 1 Guest are viewing this topic. Read 7113 times.
fmoya
    • http://www.eucor-online.com/altavoces
DVA101
« on: 10 Nov 2004, 12:51 pm »
Can C1 be bypassed in the DVA101 if I have bypassed the Buffer Amplifier too (my CD player has coupling capacitors)?
Regards.
davidw
    • http://www.wnaudio.com
DVA101
« Reply #1 on: 15 Nov 2004, 06:17 pm »
If you're using fet opamps in the buffer amplifier then you can probably omit the capacitor at the input of the dva101. Check to see what the dc offset is at the output of the dva101 before you connect a loudspeaker. Anything under 50mV will be fine.
David
