What's your favorite recording of Holst: The Planets?
0 Members and 1 Guest are viewing this topic. Read 11508 times.
Double Ugly
« Reply #40 on: 18 Nov 2004, 12:19 am »
Quote from: Tyson
The cannon blasts on John's rec are over the top insane.  You had better have some serious woofage to pull it off.  If you don't, then listening to it too loud will blow your woofers.
More good info.  Thanks, Tyson.
Do you have recording you prefer to John's recommendation?
DU
« Reply #41 on: 18 Nov 2004, 01:02 am »
This is the one I like, plus it's got some great performances of other Tchaikovsky music:
http://www.amazon.com/exec/obidos/tg/detail/-/B0000041SS/qid=1100739273/sr=1-18/ref=sr_1_18/102-6845006-8736141?v=glance&s=classical" target="_blank" class="postlink">Dorati's Tchaikovsky
Double Ugly
« Reply #42 on: 18 Nov 2004, 01:15 am »
Thanks again.
DU
« Reply #43 on: 18 Nov 2004, 06:00 am »
I would also recommend checking out the Tchaikovsky Piano Concerto and his Violin Concerto, both are very good pieces of music, and are very accessable (ie, they have lots of good tunes in them).
