0 Members and 1 Guest are viewing this topic. Read 6320 times.
If Windows 7 is working for you then stay with it, support ends in 2020 which by then you will have a new computer with Win 10 anyway. Some software will no longer work with Windows 10 like old printer drivers for old HP printers.Windows 10 may also fail to install if there in no updated driver for an onboard graphics chip. The workaround is to make an install disk with the Windows 10 Media Creation Tool.http://www.audiocircle.com/index.php?topic=134981.msg1536764#msg1536764The Windows 10 Media Creation Tool Install Disk also allows you to do a clean install of Windows 10, register with the license number on the back of your Windows 7 disk. Backup your date first of course.
I have W7 and no problems. Works great. I did elect to upgrade to W10 today but I don't think it is working. I keep getting the message that one update failed to install. My only options are to cancel or try again. That just repeats the process. Stuck in a "do loop". At least I think there was a cancel option. Waiting for the merry-go-round to go-round again.
Seems microsoft dont want I fix my W7, they already give me 2 links failed to download the patch, the first link was incomplete:https://www.microsoft.com/pt-br/software-download/windows7And the second link always abended in 2.7GB:http://software-download.microsoft.com/pr/Win7_Pro_SP1_BrazilianPortuguese_x64.iso?t=1a0d518c-e988-4820-8116-5aeeb92ea343&e=1469477411&h=dc77c0d5937e0d3f243d23a62deb0206
I upgraded to Win 10 last night and ended up deleting it because it made my computer run really slow. I did make a back up of my Win 8.1 and reinstalled it. I have the Win 10 key now and I will do a clean install of Win 10 eventually. This is the best way to do it. A lot of people are having problems with their computers running slow after installing Win 10 without a total clean install. If you don't want to upgrade yet, you should download it and get the Win 10 key so you can upgrade for free in the future.
Here is a online tutorial explaining what you need to do use windows 10 without a product key. Apparently Microsoft wants people to use Win 10, even if they don't activate it and pay. http://www.howtogeek.com/244678/you-dont-need-a-product-key-to-install-and-use-windows-10/All you need to do is go to the Microsoft website and use the media creation tool to create a copy of Win 10 on a DVD or flash drive, which you can put on your machine at any time and activate if desired. I used the media creation tool to put a copy on a flash drive to upgrade my MS-2 PC Music Server. Worked like a charm.Scotty
