Best solid state amp for Super Alnico Monitors?
0 Members and 1 Guest are viewing this topic. Read 10013 times.
doggie
Re: Best solid state amp for Super Alnico Monitors?
« Reply #20 on: 22 Aug 2016, 06:18 pm »
A few days ago I picked up a Sonneteer Campion integrated and have been playing it with my Super Alnico high output 1.5 floor standers ever since......extremely good match.  I can only imagine what the newer model Alabaster would sound like.
Nope. An after market cord.Signal Cable.
Sense63
« Reply #21 on: 25 Aug 2016, 03:39 pm »
I'm confused by your post........I have purchased the Alabaster and it is a nice step up.  Still a great match with the Omegas.
« Last Edit: 30 Aug 2016, 03:04 pm by Sense63 »
RDavidson
« Reply #22 on: 26 Aug 2016, 02:22 am »
Your post makes no sense.  I have purchased the Alabaster and it is a nice step up.  Still a great match with the Omegas.
Signal Cable is the brand. Hope this clears up the confusion.
Sense63
« Reply #23 on: 26 Aug 2016, 02:28 am »
Right.  Signal Cable is a cable company that only makes cables.
opnly bafld
« Reply #24 on: 26 Aug 2016, 02:43 am »
doggie quoted the wrong post.
I have been running a First Watt SIT2 with my Omega Super 6 Alnico's for about a year and it is indeed a great match.
Are you using the stock power cord?
Nope. An after market cord. Signal Cable.
ohenry
« Reply #25 on: 26 Aug 2016, 04:07 am »
Nelson's Amp Camp Amps work well with efficient single drivers.  Class A goodness in a small affordable package.  They aren't difficult to build either.
http://diyaudiostore.com/products/amp-camp-amp-kit
doggie
« Reply #26 on: 26 Aug 2016, 07:04 pm »
Thanks opnly bafld. You are right. I misquoted and I did leave everyone openly baffled!
doggie
« Reply #27 on: 26 Aug 2016, 07:08 pm »
+1 for the Amp Camp amps. A friend brought them over to try with my Omega Alnicos and they sounded great. An excellent value...
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« Reply #28 on: 6 Nov 2016, 11:14 pm »
Old thread, but have to post that I built a pair of the Pass Amp Camp monoblocs - finished a week ago.  Running with a 24v switching power supply rather than the 19v.  I am quite surprised with how good they sound.  They are powering SAM's.  Makes me want to try a First Watt.  J2 or SIT-2.  Or a used Aleph if I could find one.  A pair of linear 24v supplies with at least 2 amps each would be kind of pricey for the ACA's.  That would bring them a step up, but would double their original kit cost.
.......Peter
Using a quiet, low speed fan since the 24v PS brings the heat up quite a bit.
