Download speed...
0 Members and 1 Guest are viewing this topic. Read 19496 times.
lcrim
Re: Download speed...
« Reply #80 on: 27 Aug 2016, 03:14 am »
Very large technical point here is that unless this speed test is conducted via wired ethernet  not wireless, you are only measuring your wireless speed from client computer to the broadband router.
Larry
Guy 13
« Reply #81 on: 27 Aug 2016, 03:20 am »
Larry
Larry, are you sure about that.
With two same wi-fi units, but with different Internet provider
I get very different download speed ? ? ?  ?   :scratch: :scratch:
Guy 13
on planet Vietnam.
lcrim
« Reply #82 on: 27 Aug 2016, 03:45 am »
Perhaps I should clarify, your measured internet connection speed will be affected by many factors.  Removing as many of these slowdowns will result in greater accuracy.  Wireless connections or 802.11 a,b,g, n,ac connect at different speeds plus obstacles like floors, walls, ducting, microwaves etc. have an affect.  A wired ethernet connection directly to the cable modem will remove nearly all these issues.  Rebooting all the constituent devices is also a good idea.  There will still be differences between tests,  Most test sites will provide a ping time and a latency figure which are other measurements that can be a concern.
Larry
Guy 13
« Reply #83 on: 27 Aug 2016, 04:00 am »
I did try direct connection from my modem to the laptop vs via wi-fi
and I did not see any differences between the two ? ? ? ? ?  :scratch:
Guy 13
on planet Vietnam.
Guy 13
« Reply #84 on: 1 Sep 2016, 12:02 pm »
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #85 on: 1 Sep 2016, 12:09 pm »
 :lol: :lol: :lol:
MtnHam
  • SoundLab and Fritz Speakers Dealer
« Reply #86 on: 2 Sep 2016, 01:22 am »
Wi-Fi connections to the internet can be a compromise, whereas a direct wired connection to the modem will tell you your true connection speed.
« Reply #87 on: 7 Jan 2017, 12:52 am »
Comcast just gave me a free upgrade. Now averaging about 235 Mbps download. Not bad  :thumb:
Speed test results
zybar
« Reply #88 on: 7 Jan 2017, 01:00 am »
Speed test results
I miss FIOS.
WGH
« Reply #89 on: 7 Jan 2017, 01:35 am »
Speed test results
What is your monthly Comcast bill? (Just saw $89 for the first year)
My internet is $36 a month with a blistering 14Mbps, usually website servers are still slower than my connection.
But I live alone, with a family all streaming different videos at the same time I can see the need for speed.
« Reply #90 on: 7 Jan 2017, 01:54 am »
My first year deal is over and it's gone up to $130 a month. The high charge is mostly for things my wife likes and I never use  :duh:
Higher than I like, but the service is excellent. It's never down and Tidal streaming never has hiccups, even with the new MQA streams. I listen to Tidal constantly so this is really important to me. Blistering fast downloads when I'm downloading Tidal albums to my phone for offline use. I can usually download a full album to my phone in a few seconds. Ludicrous fast!
