Adapting subwoofer amp?
0 Members and 1 Guest are viewing this topic. Read 2480 times.
grub
« on: 9 Nov 2004, 05:24 am »
Hey all,
I've recently picked up a QSC RMX 2450 to power my passive HT sub.  I'm having trouble adapting my sub-out (RCA) on my reciever to fit into the TRS jacks on the sub amp.  I went to ratshack and picked up a slew of adaptors, but I can't seem to get much but noise from the sub though.
When I use the female RCA to mono TRS adaptor I get sound, but I have a VERY loud hum on top of it.  The hum changes volume with the controls, and I think it might be a ground loop.  The trouble is that I get the exact same hum when I try other AC outlets and unplug other components in my HT.  I tried to troubleshoot it by plugging in my minidisk player mic into the sub amp, and when I do I get a signal and a dead-quite backround (except for the amp fan).
I also used a femal RCA to stereo TRS adaptor, hoping that would take care of the problem, but then I had no signal at all...nothing.  I even went  so far as to cut one end of a spare RCA cable off and hook it up with the barrier strip inputs....same hum.
Does anyone know what's causing this hum, and what I can do to get rid of it?  I just ordered a proper cable with a TRS jack on one end and an RCA on the other.  I'm hoping this solves the problem, but I'm open to suggestions.  It's a real drag having a new toy in the house but not being able to use it!
Thanks guys,
-->grub
grub
« Reply #1 on: 11 Nov 2004, 10:26 pm »
problem solved........it was noise coming from the cable line.
It was a tricky problem to diagnose, but I un-hooked everything and re-connected components to my reciever one at a time.  The VCR and cable box both induced a loud, low hum in the sub amp.  Fortunately my power conditioner has a filter for coax and it took care of the problem.
FYI for others out there with a similar problem.
-->grub
ctviggen
« Reply #2 on: 11 Nov 2004, 10:36 pm »
If you own the house, you might take a look at how your cable is grounded.  It might not be grounded at all (my house) or grounded incorrectly (mine's now grounded correctly).
rosconey
« Reply #3 on: 11 Nov 2004, 11:06 pm »
yup cable can be a bitch :evil:
StevenACNJ
« Reply #4 on: 12 Nov 2004, 11:16 am »
Quote from: ctviggen
I am not sure my cable is grounded. But how should it be grounded?
zybar
« Reply #5 on: 13 Nov 2004, 05:03 am »
Did anybody ever explain how it should be grounded?
I am getting a loud hum all of a sudden when my satelite feed is screwed into my DirecTV reciever.
George
StevenACNJ
« Reply #6 on: 13 Nov 2004, 02:20 pm »
Quote from: zybar
George
I use a Jensen Model VRD-1FF cable TV RF isolator for my incoming cable line. Totally cleaned up all hum problems.
Link:
http://www.jensen-transformers.com/iso_vid.html
