Bryston amps and Isotek Power Conditioner
0 Members and 1 Guest are viewing this topic. Read 8508 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston amps and Isotek Power Conditioner
« Reply #20 on: 14 Jul 2016, 09:56 am »
HI Folks
Here is a review on the Torus unit but it is identical to our Bryston BIT units.
http://www.stereotimes.com/post/torus-avr-20-ac-conditioner/
james
Rod_S
« Reply #21 on: 15 Jul 2016, 08:58 pm »
I plead the fifth!
james
LOL..I see you think very highly of those designs :D
Gibalok
  • Metrum Pavane/Manley Shrimp/4BSST2/Penaudio Cenya
« Reply #22 on: 16 Jul 2016, 06:24 am »
Another BIT/Torus topic.. ^)
James, please explain how power amplifier (in my case 4bsst2) and other componnets like pre amp, CD transoprt and a DAC a isolated from each other in Torus (I have RM 16 CE).
Are the any logic should be to connect components to the sockets? or all 8 sockets at RM 16 CE are identical?
PS Im quite happy with Torus and feel that it is a solid base for my system.. I have changed preamp, speakers, dacs.. but would never in any case sell the Torus (only if to get the last and most powerfull BIT.. sometime..)
« Reply #23 on: 16 Jul 2016, 10:17 am »
Hi Gibalok
The outputs are all in parallel so it does not matter which one you use.
james
Gibalok
« Reply #24 on: 16 Jul 2016, 03:21 pm »
Hi Gibalok
james
and there is no interference among lets say power amp and DAC?
« Reply #25 on: 16 Jul 2016, 03:29 pm »
Not with an islotion transformer.
james
Gibalok
« Reply #26 on: 16 Jul 2016, 04:14 pm »
james
Thank you!
Gibalok
« Reply #27 on: 16 Aug 2016, 01:57 pm »
I dont have a fifth of anything :duh:
I went thru 5 hydra 2's(amps),hydra 6(components)
DEDICATED LINES :D,also.......shunyata python helixes,anaconada helixes....12 cables all together,                                                           The Money rub for sure and not talking BBQ.
Demoed one Torus(BIT)15a ,couldn't do all the amps (mains for sure),
picked up a used 20a...split the amps 3x7's ..plus 2 x b's,2 x DD15,plus components.
soon as I connected the second Torus to relieve the strian on the amps as with the one the shunyata and torus sounded------------------------------
soon as the second Torus and were talking INSTANTANEOUS...NOW factor..SHOWTIME
slam, bottom tighter moree like a a live event.
Sorry I would never buy shunyata,hey had the top cables,Hydras ect...BS
Audio10 shows what goes into a hydra 4,also there are picts of a hydra 6 insides BS
Had my Torus(s)6-7 yr,they stay my cables and shunyata ...friggin dust in the wind...pure imagination at least thats what I heard .nothing,
stock cables with Torus ....you dont need fancy expensive cables,sides they just put friggin foam pipe insulation to give that AWWW effect...been on the puzzle trail for yrs glad I got most of my money back on the cables.
Haven't found or heard yet nothing better than the Torus(BIT and if Ido I'll change up as I love my music the best it can be...............................
Could you please advise. At the moment i have Torus power rm16 ce (16 amperes) connected with moderate 5.5 sq.mm gauge (9 awg if im not mistaken) it is Oyaide Tunami 3m POCC copper to the wall with wattgate premium connectors (390/350). From the Torus to Bryston 4bsst2 i use 9awg Saec AC-7000 power cord with Furutech 38/28 connectors.
The question is: should i expect more slam/dynamics with using Shunyata python or anaconda power cords for Torus Power or from Torus to power amp 4bsst2?
I red a lot good things on top Shunyata cables..
