For Sale: Sony SS-NA5ES, Brand new in sealed boxes
0 Members and 1 Guest are viewing this topic. Read 1732 times.
failynn
Brand new pair in sealed boxes. I have two sets of these: bought one set and loved them so much I bought another pair for a planned listening room that has not materialized. Audiophile quality for sure. Stereophile's call: "Masterpiece!" Look up the review online. They just get music right.
Priced to sell. Price is not negotiable. Shipping, insurance and paypal included. $3,795. Will also accept Chase quickpay.
 SS-NA5ES
 Sound unrestricted by size
 The SS-NA5ES bookshelf speakers have been designed in the image of the floorstanding Sony SS-NA2ES loudspeakers, utilizing the same components, cabinet materials and construction integrity to create a listening experience with an exceptionally clear, wide soundstage.
 $6,000 list price.
 Music loyal to its creator
 The bookshelf size of the NA5ES loudspeaker never restricts it from bringing forward the natural balance of the dynamism and airiness present in music as it was meant to be performed. From transcendent high frequencies to low notes felt as much as heard, the detail and richness the composer envisioned are delivered without compromise or coloration.
 Pinpoint accurate high frequencies
 Sony's innovative I-Array™ tweeter system achieves the wide dispersion and ambience of original recordings without adding any unnatural artifacts to the sound. The result is astonishingly smooth highs with increased resolution, broader soundstage and a delicate but precise sound image.
 Inherited strength
 Building on the Sony AR Series' legacy of rock-solid loudspeaker construction, the SS-NA2ES cabinet is made of Scandinavian birch, a wood highly regarded for its acoustic resonance and performance. Within, the woofer is isolated from other drivers by two distinct separation boards to preserve the critical sonic purity of the mid range frequencies. Sony's expert woodworkers meticulously craft each precise enclosure to a degree of perfection that's as pleasing to the eye as it is to
 the ear.
 Ready for the theater
 The entire Sony ES line of loudspeakers have been matched to work together flawlessly not only to deliver the most lifelike reproduction of music, but also to bring impactful excitement to movie soundtracks.
 System
•2-way, 4-driver, bass reflex, bookshelf speaker system
 Drivers
•25 mm soft-dome tweeter
•Two 19 mm soft-dome tweeters
•130 mm aluminum-cone woofer
 Frequency Response
•45 Hz to 45 kHz (-10dB)
 Sensitivity
•86 dB (2.83 V/m)
 Rated Impedance
•4 ohms
 Maximum Instantaneous
 Input Power
•70 watts (non-clipping)
 Dimensions (WxHxD)
•Including projecting parts
•8.0 x 14.0 x 12.8 inches (205 x 355 x 325 mm)
 Weight
•22 lbs. (10 kg)
 http://www.sonypremiumhome.com/es-speakers/SS-NA5ES.php
