Video files help
0 Members and 1 Guest are viewing this topic. Read 823 times.
Peter J
  • Hmmmm
Video files help
« on: 2 Jul 2016, 02:25 pm »
A coworker gave my wife a USB thumb drive with movies on it. I looked at it and the files are MP4s averaging around 1-1.5 GB.
She would like to watch these on iPad during upcoming long flight but I really don't know how to make these viewable on that device without USB.
 She was told it could be done with iTunes, but I admit to knowing almost zilch about iTunes, never having used it.
Guidance is appreciated.
srb
Re: Video files help
« Reply #1 on: 2 Jul 2016, 02:50 pm »
Peter,
You can add the movies to iTunes by (a) File > Add File to Library, (b) File > Add Folder to Library or (c) Drag and Drop to "Library" in the left side Sidebar (View > Show Sidebar).
When you connect your iPad to the computer with the sync/charging USB cable, it will appear as a device (after a slight delay as it's being recognized).  You can choose what data you want to sync to the iPad (music, videos, contacts, calendar, etc.)
If the files show up as TV Shows and you want them to be categorized as Movies, you can change the Media Kind under Edit > Get Info > Options Tab.
