Cheap Cheerful and versatile Pre Amps
0 Members and 1 Guest are viewing this topic. Read 15427 times.
prighello
Re: Cheap Cheerful and versatile Pre Amps
« Reply #40 on: 5 Aug 2016, 09:02 pm »
I had a Z pre for awhile and as small pre it was very good. The Emotiva DC-1 can also be used as a pre but only has on analog input. That new Emotiva PT-100 though looks very nice for the price. I just wish they would make a smaller form factor one with the same functionality.
Poultrygeist
« Reply #41 on: 6 Aug 2016, 01:26 pm »
I'd recommend something really cheap and really good. This $35 Sain Smart from Amazon is practically plug and play.
https://www.amazon.com/SainSmart-Assembled-Headphone-Amplifier-Transformer/dp/B008BGLN5G/ref=sr_1_1?ie=UTF8&qid=1470488890&sr=8-1&keywords=Sain+Smart+6n3
Add an inexpensive input switching box like this one for $15 for multiple input requirements.
http://www.ebay.com/itm/REALISTIC-42-2110-STEREO-AUDIO-SOURCE-SELECTOR-SWITCH-RADIO-SHACK-WORKS-/302032940327
And this $42 Sabre DAC would provide a digital to analog source.
http://hifimediy.com/sabre-dac-uae23
All for less than $100  :thumb:
OzarkTom
« Reply #42 on: 6 Aug 2016, 04:50 pm »
Then add the DIY Glow speakers for $248.
http://www.glow-audio.com/glowkit.html
And the Lepal amp with remote for $24, for less then 400 bucks, you have a ridiculous good sounding system. :thumb:
https://www.amazon.com/Lepai-LP-A68-Digital-Amplifier-Remote/dp/B00721Z1AE/ref=sr_1_2?ie=UTF8&qid=1470501709&sr=8-2&keywords=lepai+amp
